Drag Racing Tech
S60 or 9"?
Old Jun 27, 2007 | 12:30 PM
TS6's Avatar
TS6
Default S60 or 9"?
I need a stronger rear end than my 12 bolt, which would be best for me, the S60 or 9"? I plan to have it narrowed a couple inches per side also. My car weighs about 3800-3900 with driver, makes about 750 RWHP. No trans brake for now, but I wanna leave the line as hard as possible. I think between the weight and power the 12 bolt would break. I'd like to put this in the high 9's, its got the MPH but will need a good short time.
Also this car is primarily used on the street. I go to the track just a few times a year. So no spool for me, and even the Detroit locker sounds a little rough for street use from what I've seen.
Thanks for any help!
Old Jun 27, 2007 | 05:32 PM
Firehawk441's Avatar
I prefer the 9" over the Dana. It's a MUCH simpler rear to work on and will take all the abuse you can throw at it. The Dana does however have a bigger ring gear. It's also a bit heavier.
Old Jun 27, 2007 | 05:45 PM
gator's 99TA's Avatar
the dana is a simple as a 12 bolt, 10 bolt, or 8.8.
Old Jun 27, 2007 | 07:08 PM
z-ya's Avatar
9"no pinion support on the s60.
Old Jun 27, 2007 | 07:40 PM
Torkman15's Avatar
10 Second Moderator
My vote is also 9 inch. Its proven itself time and time again plus on my 9 I got the gun drilled 35 spline axles and they are lighter than the 33 spline solid axles they are replacing. Heavy but proven performer. When I pull out my 12 bolt I'll weigh them both full of fluid side by side and figure out how much heavier if any the 9 is. (I also got the aluminum housing center section, 4.56 and lightweight spool)
Old Jun 27, 2007 | 08:26 PM
1cdub's Avatar
S60....what it add's in weight, it makes up for in efficiency. Oh and its stronger, a bit cheaper, and who wants ford parts on their car anyway
Old Jun 27, 2007 | 09:03 PM
6techniques's Avatar
You really cant go wrong with either they're both strong as an ox...just go with the one you can get the best price on.
I went 9" because it was ALOT cheaper for me. (new housing/axles, used center w/ spool and 3.50's) less than $1200
Old Jun 27, 2007 | 09:22 PM
Jpr5690's Avatar
From What I Was Told 750 Rwhp, 3900 Lbs And A Dead Hooking Car Would = A Locker Or Spool
Strange Told Me That My S-60 With A Truetrak Would Be Verry Reliable For 600rwhp And Slicks
Past That They Did Reccomend A Locker
Old Jun 27, 2007 | 09:24 PM
Jpr5690's Avatar
At Same Time Auto Tranny, Fi Car Id Bet Your Car Would Hold Up Fine With A S-60 And Truetrak
Now If You Had A M6 And Lets Say 750rwhp With A Big N20 Shot I May Think The More About The Locker ..
