Drag Racing Tech
Grinding Calipers 101
Old Jul 6, 2009 | 09:48 PM
  #81
Formula/LS1's Avatar
Just finished my 2001 Formula with Weld Prostars 15x10's and 15x4's. I would estimate I have about 15 hours of grinding and 5/16 spacers all around. I agree that testing the wheels on and off for fit was a pain in the butt. But the end result was well worth the work. The car looks great and I'm ready for some drag racing this Sunday and put some numbers on this beast. I'll be getting some pics soon and I will post my race times on the drag racing thread.
Old Jul 7, 2009 | 10:21 PM
  #82
Orr89rocz's Avatar
Good to hear you got yours to work. Same setup I used, lots of grinding and 5/16 spacers I believe.
Old Jul 14, 2009 | 09:13 AM
  #83
Troy's Avatar
This is a great write-up and the pics really help a lot. I really don't know if I feel safe doing that much grinding with a semi-daily driven/beat on car (and possibly handing the car down to my son's some day). The front seems like barely any grinding with my 15x3.5 ProStars and spacers but what calipers can you all recommend for the rear? I have 15x10 ProStars for the rear and would prefer to keep the integrity of the rear calipers for the above reasons.
Thanks...
Old Jul 14, 2009 | 12:20 PM
  #84
AChotrod's Avatar
My old prostars on my LT1 required NO grinding or spacers in the rear with pads about 50% left, My Greg Weld fronts fit with NO grinding or spacer also
My Greg weld rears took about 15hrs to fit and I used sanding discs (i think120 grit) with a angle grinder and the paint method
Also the window on the back of the LT1 rear caliper is much smaller than the LS1 so not as scary when taking down the back side. I will be buying drag brakes but not to worried untill then
Old Jul 14, 2009 | 12:36 PM
  #85
Troy's Avatar
Sorry, I should've clarified, this is for a LS1
Old Jul 14, 2009 | 12:45 PM
  #86
01z's Avatar
01z
so you guys are grinding and still having to use spacers in the rear for the weld rims??
Old Jul 14, 2009 | 04:48 PM
  #87
Orr89rocz's Avatar
with new brake pads you may need to also use spacer... i didnt want to grind THAT much off so i dont mind the smaller spacer
Old Jul 14, 2009 | 05:40 PM
  #88
Camaro396's Avatar
Depends what Weld rims. Weld R/T series wheels (in sig) are a direct fit for LS1 cars.
Old Jul 15, 2009 | 03:15 AM
  #89
01z's Avatar
01z
i just have regular draglites, i grinded the **** out of my calipers but they are still scrubbing a little. i dont want to grind any more though. guess its time to buy some spacers. so is 5/16 the usual spacer in the rear?? i dont want them sticking out like a cholo.
Old Jun 22, 2010 | 11:40 PM
  #90
01_ram-air's Avatar
Bump for the newbs..
Old Jun 23, 2010 | 11:24 AM
  #91
AChotrod's Avatar
yeah I know just pointing it out for the Lt guys. Another and probably safer option for the LS guys is to swap to LT rear brakes. That way very little or no grinding or spacers are required. Stopping power/distance wont even be noticed.
Not to mention you can find Lt stuff CHEAP.
Old Nov 15, 2010 | 05:52 AM
  #92
bird383's Avatar
Wow , i tried gring on my 02 for rear 15x10 it was useless, i gave up
Old Nov 17, 2010 | 06:37 PM
  #93
Mike 02T/A's Avatar
Excellent Writeup!
I was grinding forever on the rears for ProStars. Gave up and ran a small spacer : )
Old Aug 6, 2011 | 12:30 PM
  #94
s25hanh's Avatar
sorry to revive an old thread but i have the same problem as him with my weld draglite 15x10's and i dont want it sticking out like crazy.
Old Aug 11, 2011 | 10:31 PM
  #95
1Bad97WS-6's Avatar
I'am running the Jegs Sport Stars 15x4 and 15x8s.. The front required grinding. The backs I had to grind a little also but not as much as weld wheels.. I'am not using no spacers front or back.
Old Aug 12, 2011 | 01:15 PM
  #96
s25hanh's Avatar
what is a pretty good spacer to run with minimal grinding and not looking like a retard with em sticking it
Old Aug 12, 2011 | 02:51 PM
  #97
subhumanzz's Avatar
5/16"
Old Dec 9, 2011 | 03:02 PM
  #98
1Bad97WS-6's Avatar
On the caliper where is the fin located at. Because I'm gonna buy the Race star wheels and people are saying they had to grind the fin maybe 5 min a caliper. I probably grinded them off since I had to grind for my jeg star wheels..
Old Mar 9, 2012 | 01:02 PM
  #99
LSXFEIN's Avatar
Default what kind of GRINDER????
Sorry to bring up this old thread but can somebody please specify what kind of grinder..is it an electric or a air powered die grinder?????????????? anyone please thanks!!!
Old May 10, 2012 | 12:23 AM
  #100
01_ram-air's Avatar
I used an electric grinder. The better quality the grinder, the less amount of time it will take. I started with a real cheap one and it was a pain. Borrowed a buddy's nice grinder and started flying through it.
By Brett Foote | 2026-06-04 05:00:17
