Question for People running BFG Drag Radials.
I have been running 315/35/17 Nitto 555Rs and have switched over to a set of 315/35/17 BFG DRs and I'm wondering the best tire pressure to run in them at the track. I use to run around 20#s in the Nittos but when I tried that with the BFGs they felt like they were wadding up on takeoff. Its gonna be at least 90 degrees out there at the track tonite and I was wondering what tire pressure was working for other people. Do these tire like to be heated up real good in the burnout before they stick. I know for a fact the Nittos just wanted a lite hazing or they would just melt/spin with out hooking up. I have gotten 1.67 60 ft times with the Nittos and I am hoping these BFGs will do better.
In my 3800lb Cobra the best (most consistent) psi was at ~16lbs and I had consistent 1.7 short times on stock suspension. And a good 5-6 second burnout ususally did the trick on warm (80*+) days. But honestly, the only thing I can tell you is do what works for you as each car is different and BFG's are a good tire and it seemed that you dont have to drop them down as much compared to other tires but thats just from my experiences.
Originally Posted by MARKSZ71
mine liked 16psi im sure u know but mickey t drag radials are the best way to go
Originally Posted by NC98Z
Well I would have to run a 315/35/17 and the last time I checked they still had not released that size to the public for sale yet. I've been waiting a long time for them to come out with a size I can run.
-brandon
I ran the 315/35/17 BFG's @ 18psi before that .. 1.64 60'. 5-6 sec. burnout. SS3600, launched @ 2K.
Good luck!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
how do the bfg and/or m/t size up compared to the nitto/ i always hated nittos but i just picked up some wheels that already has 315/35/17 dr's mounted, but im debating on buying some m/t dr's instead. my other debate is if ill wait for m/t to come out with their sizes for 18" wheels.
