Strength of 12 bolt vs. 9" posi....
run it til it breaks and then put a spool in it. if you don't want to worry about it, put the spool in now. if you want unpredictable lock up/torque steer and clicking noises put the locker in it.
For all those that brag about how strong a locker is and the driveability isn't such an issue, etc...think about it like this, a spool will be stronger, doesn't ever unlock, they weight 5-10#'s depending on what you're willing to spend and are far cheaper.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
For all those that brag about how strong a locker is and the driveability isn't such an issue, etc...think about it like this, a spool will be stronger, doesn't ever unlock, they weight 5-10#'s depending on what you're willing to spend and are far cheaper.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
+1 An aftermarket 12 bolt or 9 inch with a spool is pretty tough. I have a Spooled Moser 12 bolt in my 3rd gen thats ok on the street and no breakage issues with trans brake launches at 75% of peak power. I don't drive in the rain, but we don't have much of that here. If it's a week end car or your hard core I would say, put the spool in. If you can't live with it switch to a locker.
Like most, I do have to tighten the TA bolts on the 12 bolt every so often.
Originally Posted by Jaspirr
Don't mean to hijack the thread but..
I see everyone trashing the Detroit True Trac. I have one in my 9" from DLS. I'm hoping to make 550rwhp on spray and run high 10's with Mickey DR's.
Is a True Trac still junk for my goals? The car is 99.8% street time, so I really didn't want a posi or locker.
Its every bit as comfortable as a posi, except it spins both tires everytime, whereas my Eaton posi was a hit or miss kind of thing, even after replacing it once.
Originally Posted by JL ws-6
I've seen a 330 hp bolton car break a trutrac....... that falls in the junk catagory IMO
was it in a 12 bolt or a 9in?
LS1TECH Sponsor
LOL!, maybe I've been under a rock but we've got a car running a truetrac 9" that has cut 1.4x sixtys in a 3700 lb. full weight f-body with a six speed. Its making just shy of 600 rwhp with nothing other than a cam, boltons, and spray. Another LT1 car we're running cuts 1.5 sixtys with a truetrac in a 12 bolt, also a 6 speed.
My car cuts 1.2x sixtys with the eaton posi in a 12 bolt with an A3. The car weighs 3350 lbs. The same posi survived two years of clutch drops from 6500-7000 rpms in a 3500 lb car cutting 1.4 sixtys. Its still working good today.
Actually, the "Trac Loc" is what comes standard in the moser 9" rears. It is nothing like the detroit truetrac.
The only reason I would consider a spool is simply the weight savings. I will never run another detroit locker, especially in a manual tranny car.
I ran a spool on the street for years in my 12 bolt but I'd go with a locker and 9 inch if I were to do it again...
Spools are a bit of a pain in the **** on the street but can be manageable.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#32
Race your car!
Originally Posted by 02NBMWS6
dont know what to say about that, my car is pushing way more power and is surely just as heavy and I beat the crap out of mine and its golden. sorry about your friends luck.
#33
Originally Posted by Bitemark46
Very true on your points. However, try to take an exit/on ramp in the ran with a spool or turn into traffic in the rain with a spool. In tight turns a spool adds extra stress to the inside axle. If its a street car, I atleast want a diff that will allow the tires to spin at different speeds. -Mark
I dislike lockers for the reasons I mentioned earlier and I'd rather deal with tire chatter from the spool than the unpredictableness of the locker locking/unlocking when getting on/off the gas.
#34
The way I drive I give it gas in the corner but ever so gently. It doesn't lock until I'm straight then I apply more gas and it does the sudden surge to one side as it locks. I know it sounds crazy but I guess it depends on how tight of a turn. I wish I could take you for a spin. You hardly notice it. It took me a few months to get the hang of it. But to each his own. I'll take the locking/unlocking over added stress to the inside axle and tire wear. -Mark
#35
Originally Posted by vtec
so, the tire chirping would be louder than your 730+rwhp supercharged car? lol....
i will say that i personally know 2 people that broke their eatons. both m6 cars with nowhere near your power. i would probably run a locker in a 9" if its mostly street, or a spool if its mostly track.
i HATE my detroit locker on the street. i will be going to a spool. and i will DD it. when the locker locks and unlocks its a scary feeling going around a corner
