Shortened rear check
What tire you planning on running? That will be the critical factor in how much clearancing you will need to do.
I have a Strange 12 bolt shortened 2.5 inches each side with a 5.5 BS Pro Star XP. I am running a 275 60 15 with a 1/4 inch billet spacer and still had to beat the inner fenders a bit. I went ahead and cut out the bumpstops and I run offset bushings on my LCAs as I plan on running a wider tire at some point.
Its a bit of work to get everything to play nice with each other but the end justifies the means. You will love the way it looks when its finally done.
M&H 325/50/15 Height 28" Tread Width 10.3 Section Width 12.3
M/T 325/50/15 Height 28" Tread Width 11 Section Width 13.0
BFG 325/50/15 Height 28" Tread Width 10.5 Section Width 13.0
The M&H with the section width of 12.3 is the same as a nitto 315/35/17. I'll still need to remove the bumb stop but don't think I will have to do any hammering.
I'll post pics once everything comes in. Should be in about 3 weeks.
