Drag Racing Tech
What should I expect?
Old Jun 7, 2007 | 09:54 AM
GDM Z28's Avatar
Default What should I expect?
We all have our goals but am I expecting too much?
I have a 98 Camaro with the following mods:
LQ9 bottom end, LS6 heads, 236/238 605/609 @ 112lsa cam, built 4l60e tranny, 3600 fuddle converter, 3.42 gears, bolt ons, T NT nitrous kit, SFC's, Adj. LCA's, Tubular k member, adj, upper a arms, and a few other things here and there. What could i honestly expect to run with this thing?
Old Jul 22, 2007 | 12:37 AM
yobabiesdaddy2001's Avatar
how did your car turn out man?
Old Jul 22, 2007 | 04:42 AM
98CamZ28's Avatar
Depending on how everything is setup and how much you're spraying i'd say decently into the 10's
Old Jul 22, 2007 | 08:49 AM
gator's 99TA's Avatar
what tire and what do you expect to 60'? i will ASSume you go 1.45-1.50 60 and are spraying a 150 shot - you should run 10.9-10.75 without a problem. again its more to do with how well you get out of the hole and what is a "lot" of nitrous
Old Jul 23, 2007 | 11:09 AM
GDM Z28's Avatar
well i ran it un tuned and i left like a bitch because Jeremy Formatto is up here at the shop i work at today and tomorrow and i didnt want to break the rear. i stalled it up to about a 1000 and rolled into it slowly cut a 1.7 and car went 12.1 on motor with a stock ls1 intake manifold. I put a ls6 on it now and im going to tune it tonight. i forgot what the nitrous is jetted at but its either a 150 or a 175 tnt (so like a 175 or 200 nx). hopefully ill get it into the 10's if not ill be pulling more weight out of it.
Only thing really hurting me is the stock rear.
Old Jul 23, 2007 | 11:11 AM
how much does it weigh?
Old Jul 23, 2007 | 01:28 PM
sounds like 10s shouldnt be a problem. those TNT kits hit HARD
Old Jul 24, 2007 | 09:12 AM
GDM Z28's Avatar
havent weighed it yet but i did take some weight out of it already.
Old Jul 24, 2007 | 12:29 PM
Got Me SOM's Avatar
i agree high 10 capable but getting a 1.4 or 1.5 60' won't be easy at moroso.
are you stock bottom end or forged ls2?
Old Jul 24, 2007 | 12:31 PM
I have a lq9 that I am installing with Edelbrock terminator heads and a ms3 with a fast 70mm.
or maybe a terminator that I have
