Drag Racing Tech
15x8 or 15x10
Old Jul 25, 2007 | 01:58 AM
SnakesRslow's Avatar
Default 15x8 or 15x10
im looking into a set of draglite's from either jegs or summit. I have a set of 26x11.50 et streets. question is, What would be better for me to buy the 8 or the 10" wheels? also will i have to pull off the eibach lowering springs and replace with the stock springs? or better yet will it be beneficial for me to do so?
Old Jul 25, 2007 | 09:21 PM
1nastyss's Avatar
id go with thw 15x10's, that a way u will have more choices between different size tires
Old Jul 25, 2007 | 09:36 PM
Strahley's Avatar
Agreed, 15x10. You can always go bigger or smaller on the tire if you want. With 15x8, you'd have to make the jump to 15x10 later on if you wanted to get much bigger with the tire
Old Jul 25, 2007 | 09:45 PM
promod1955's Avatar
I would also suggest the 10" wide wheel. When the day comes that your making more hp and want to go up in tire size, you wont have to buy new wider wheels.
I ran the exact tire on a 10" wide wheel and got a 1.50 60ft in a 3400 lb stock internal car. It's a good combo.
BTW, I like the 55 in the garage!
Old Jul 26, 2007 | 12:19 AM
thanks, its a fun ongoing project.. thats about to get my old 4l60
Thanks for the replies looks like im going with the 10" wides.
Anyone know if that tire/wheel combo will fit with the lowering springs?
Old Jul 26, 2007 | 04:42 AM
tektrans's Avatar
15x10's...........
Old Jul 26, 2007 | 12:48 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
15x10 is what we run on all 3 Ray Family Racing Camaros.
Coach
Old Jul 26, 2007 | 02:42 PM
promod1955's Avatar
My bogarts with those 26x11.50 et steets fit great lowered about 1 1/4" in the rear. You may need an adjustable pan hard rod however.
Old Jul 28, 2007 | 06:03 AM
thanks for the info i should be picking up a bmr in the next few days
Old Jul 28, 2007 | 08:46 AM
promod1955's Avatar
no problem
