Carb Style intake guys??
Nothing wrong with NX stuff either, just surprised you didn't look into one of those.
Ya get that TB cable setup all set, when you gonna hit the track again, I'm intrested to see what you pick up going from the fast to the edlebrock, might give me some insight as to wether it would be a better route to go then porting the fast over the winter.
it fogged very even, and right into the ports.
good stuff, and the price was right.
as for the track, i wont be going for a few weeks, i have **** to do every friggin weekend in august, and i hate the friggin heat, so september will probably be my next time out.
For a 400+ci motor the carb intake or a custom sheetmetal is the only way to go... for N/A / Nitrous use....
Try both at the track and you will be a beliver....
But I can see you picking up a good bit on motor going to a differnt gear because of the 1.7 first gear in the glide, it's not like you're gonna run out of gear at the big end with a solid roller. What are planning on spinning it to, 8000?
id say i wont be out for atleast a month when the weather starts to cool off.
i havent even looked at my car in 2 weeks. the heat kills me, by the time i get out of work i just want to hang out and drink some beers. just so frigin hot.
jl, tires and gears are big differance, a car like mine that hooks real good, with a 3:73 to a 4:30 swap with my set up, i wouldnt be surprised if i dont drop 2-4 tenths (depending on what the carb style intake does.
we'll see.
