Drag Racing Tech
Carb Style intake guys??
Old Jul 25, 2007 | 09:09 AM
Noyzee's Avatar
8 second mod
Question Carb Style intake guys??
What do you do with map and IAT sensor? im going with an acufab 4 brl t-body right on top, no aircleaner.
what to do with them?
can i put the map into the hole in the t-body
Old Jul 25, 2007 | 05:28 PM
ls1408cp's Avatar
if you have the edelbrock on it should have come with brass fitting for the intake and a part to hold the map sensor, you just add a hose you can see it in the pic if you look hard
now for the iat sensor I drilled a hole in the cowl and put it though and found a rubber peice that fits tight to hold it in place. I also redid all the wires. In the pic you can see the hole I used in the cowl it sits right behind the hood
Old Jul 25, 2007 | 07:46 PM
ss496's Avatar
what ecm are you using? if its GM what tps did you use
Old Jul 25, 2007 | 09:02 PM
ls1408cp's Avatar
the accufab cam with the correct gm tps sensor
now my wilson 105mm has a ford does anyone know how to wire it?
Old Jul 26, 2007 | 07:47 AM
Noyzee's Avatar
8 second mod
good info thanks. what about the fitting on the back of the accufab, can i put a hose on that for the map?
and yes, i was planning on the one that came with the accufab, fits perfect.
Old Jul 26, 2007 | 01:43 PM
yobabiesdaddy2001's Avatar
who all makes carb style intake for the ls1
Old Jul 27, 2007 | 06:33 PM
ss496's Avatar
+1....
Old Jul 27, 2007 | 10:16 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Edelbrock makes 2 and GMPP makes one. All of which are for cathedral port heads. Then GMPP makes a L92 and LS7 carb intake also. Good thread. I'm converting to a vic jr. with my new engine going in soon.
Old Jul 28, 2007 | 01:18 PM
Noyzee's Avatar
8 second mod
have you run your car with that plate system?
Old Jul 28, 2007 | 04:09 PM
I am going to check on the pricing for the l92 carb setup.
Old Jul 28, 2007 | 06:19 PM
Phil99vette's Avatar
7 Second Club
I welded some bungs on mine and used some brab fittings and NPT bosses for my threaded sensor.
Old Jul 29, 2007 | 12:50 AM
ls1408cp's Avatar
no I just put it on the car the way I got it used. I havent sprayed my motor yet. Some of those nx plates a cool.
Old Jul 29, 2007 | 04:51 PM
OWN3D BY MY PROF!
Yeah, I plan on using one of those on my car too.
Old Jul 29, 2007 | 06:25 PM
Noyzee's Avatar
8 second mod
i got the new gen 3 plate from nx, sprays around the side, it was a more fog style then the spray bar. we tested both. the spray bar only hit the 4 side runners, the new plate hit the hole thing, so be carefull
Old Jul 31, 2007 | 12:10 AM
VH5150's Avatar
Dynojet Fan
could we get 1 to work on a c5 vette???
Old Jul 31, 2007 | 07:18 AM
Noyzee's Avatar
8 second mod
looks like it to my, but it will need a big hood
Old Jul 31, 2007 | 08:02 PM
do you have to have edelbrock fuel rail or can you use the fast of proffesional product rails>
Old Jul 31, 2007 | 09:44 PM
VH5150's Avatar
Dynojet Fan
it will, I talked to nitro dave he's gonna hook me up... he's the man for **** like that... Vic JR intake w/ custom sheetmetal elbow, and spray bar drilled inside the intake for the 1st stage.... gonna keep u peeps posted...
Old Aug 1, 2007 | 05:46 AM
1dirtyZ's Avatar
any part numbers for the L-92 mani with injector holes and rails?
any idea where i can get one?
Old Aug 2, 2007 | 08:43 AM
Noyzee's Avatar
8 second mod
i had Speed inc rails, and they would not work.
PS, dave is the man.
i think this winter he will be doing spray bars for me as well for a 1st or 2nd stage
