Drag Racing Tech
Racepack vs Autometer dash
Old Jul 25, 2007 | 12:28 PM
Phil99vette's Avatar
7 Second Club
Default Racepack vs Autometer dash
Looking at the two, they are very close in price, aside from a simple wiring setup with the racepack which may be worth more than I think what are the benefits of running an autometer dash vs a racepack? This will see some street use.
Phil
Old Jul 25, 2007 | 12:32 PM
Big Mike's Avatar
Interested to know too! I am debating on purchasing a digital dash over conventional gauges.
Old Jul 25, 2007 | 12:42 PM
7 Second Club
Well all I know now is the Rackpak for the BS3 is a special unit list is $895. Big Stuff 3 charges $385 to do the swap. The racepak will be able to display everything the BS3 monitors.
Phil
Old Jul 25, 2007 | 02:33 PM
Outlaw's Avatar
Go with the racepak
Old Jul 25, 2007 | 03:09 PM
MADMAN's Avatar
LS1Tech Sponsor
I havent used the Autometer but the Racepak is badass with the BS3
__________________
www.madmanandcoracing.com
225-343-9029
Old Jul 25, 2007 | 03:58 PM
7 Second Club
When I say autometer, I'm talking about 6 seperate guages, not an all in one package like racepak. Thanks for the input guys!
Old Jul 25, 2007 | 04:04 PM
HotRod68Camaro's Avatar
I vote Racepac. I am looking at changing from my Autometers to the Racepac but that will have to wait for a while.
Old Jul 25, 2007 | 04:27 PM
DSG's Avatar
DSG
Is the racepac only to be used with BS3?
Old Jul 25, 2007 | 04:32 PM
7 Second Club
The racepack p/n I posted was a racepak for a BS3. They make a special cable that allows the BS3. The big key is that you don't need to run any extra cables just plug and go. The guy over @ racepack said that basically anything the BS3 monitors can be displayed in custom format on the screen.
Phil
Old Jul 25, 2007 | 04:33 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Racepak hands down.......
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Jul 25, 2007 | 04:34 PM
mike moore's Avatar
No, you can use it on anything, just need the senders.
Old Jul 25, 2007 | 04:51 PM
7 Second Club
Mike,
What is the difference in the BS3 specific unit? Racepack said that you couldn't use a normal racepack with the BS3.
Old Jul 25, 2007 | 05:11 PM
Big Mike's Avatar
Which of these is needed with the BS3?
Ultra Dash Extreme
The Ultra Dash Extreme is available in a variety of configurations to fit the needs of many different applications.
250-DS-UDX: A display only model to provide instrumentation for new and existing V series data recorders. This model also features internal and external warning lights and a fully programmable 6 level shift light. ($625.00)
250-DS-UDXRP: This model comes standard with all the basic instrumentation needed to operate your vehicle. Standard features include engine rpm, water temperature, oil pressure and battery voltage. You can optionally add oil temperature and fuel pressure by simply purchasing the required sender. Need more sensors? The VNet port will allow you to add up to 32 additional channels for the ultimate in expandability. The UDXRP model can record up to 10 minutes of data which you can play back later on the LCD display. You can also upgrade this model to download recorded data to our DataLink PC software for complete analysis. ($825.00)
250-KT-LDX: This model offers the same features as the UDXRP, plus the additional hardware required to monitor the driveline RPM. The big difference between the two is the ability of the LDX to record the monitored functions and then download the data to a PC for data analysis using Racepak DataLink software. With a self-contained data recorder the LDX Logger Dash can be equipped with optional sensors to record up to a total of 32 channels of data. Sample rates up to 100/second, and 1 MB of memory, provides lots of recording time and sampling ability. Standard features of the LDX include shift light output (6 gear), external warning light output, internal warning indicator light, minimum/maximum recall, and a remote record/display switch. ($1449.00)
250-DS-UDXSR: A display only model for street rods and street machines. This model adds the features that are required on street driven vehicles, such as speedometer, odometer, high beam, parking brake and turn signal indicators. The dash also offers the ability to display water temperature, oil temperature, oil pressure, fuel level, battery voltage and tachometer. ($725.00)
300-DS-UDX6S: This model is intended for use on snowmobiles. Standard features include: engine rpm, jack shaft rpm, speedometer, odometer, four exhaust temperature inputs, water temperature, Ace M10 setting input. There are also warning inputs for the following items: oil level, water temperature, high beam, detonation, premium fuel. The dash has 10 minutes of recording time that you can play back on the LCD display or, optionally, download to our DataLink PC analysis software. Direct plug-in wire harness adapter will soon be available for most Polaris sleds. ($799.00)
300-DS-UDX2S: Like the UDX6S, this model is also intended for use on snowmobiles. It has the same sensor and warning inputs as the UDX6S but does not have the ability to record or play back data. It is intended as direct replacement for the standard OEM gauge set. ($679.00)
Old Jul 25, 2007 | 05:15 PM
7 Second Club
Ultra Dash Extreme
None of those... I listed the custom number in the 2-3 post.
250-DS-UDX-BS3
Old Jul 25, 2007 | 06:41 PM
Outlaw's Avatar
Got to keep an eye on the forsale section.. i posted this yesterday
https://ls1tech.com/forums/lsx-parts-sale/754963-racepak-ultra-dash-extreme.html
Old Jul 25, 2007 | 07:16 PM
7 Second Club
I saw it, I was about to PM you but I saw someone had already kidnapped it.
Old Jul 25, 2007 | 07:30 PM
NA$TY-TA's Avatar
Phil,
Thats so weird man..... i was looking at the same thing....
I added up all the gauges and was close.... worth the $200 more for the race pack is prob what your thinking too...
Now i havent ordered my BS3 yet so.....
So what do i need to tell them when i order it???
Something about a V-Net cable???
You were quoted $385 more?? was thaqt to send your unit back??
Cheaper to buy from the beginning that way??
Now saying this...
""The racepak will be able to display everything the BS3 monitors.""
Now that should be
Boost, FP, oil pressure, voltage, RPM, MPH, Temp. and Trans temp????
I guess all i would need is Back pressure and and EGT's
What needed to add each if its not covered under the base??
On a side Note Phil.....
are your going to use BS3 to control Boost???
Kyle
Old Jul 25, 2007 | 07:31 PM
NA$TY-TA's Avatar
I know i asked a Bajillion questions but these are things that need to be answered and i know im not the only one wanting to know..
Kyle
Old Jul 25, 2007 | 07:44 PM
ss496's Avatar
so can you add spedometer to the 250-DS-UDXRP???
Old Jul 25, 2007 | 08:15 PM
7 Second Club
Phil,
$200 more and you don't have the hassle of wiring
John said to tell them to add the racepak connection
Yeah, think its the same either way but I'd have to check.
Now saying this...
Now that should be
You've got more stuff than that.
What do you need to do to the BS3 to monitor that? I am going to load the program tonight and check it out.
John said that anything your BS3 can log or monitor can be displayed on the racepak. Racepak has a list and its pretty long and included a couple of things I didn't know you could monitor but I guess there is a sensor that will. They said if you have a VSS you can monitor vehicle speed also.
No, we're going with AMS1000 and Co2. Alreay have both.
