Drag Racing Tech
Catback to Duals Weight Saving?
Old Jul 26, 2007 | 01:24 PM
2000Z28M6's Avatar
Default Catback to Duals Weight Saving?
Would any one know how much weight I would shed by going to duals from my hooker catback?
Would it be worth it as far as weight reduction goes?
Real #s would help..How much does the hooker weigh and what do duals weight (TSP duals or similar)?
Any help appreciated.
If all goes well, im getting a pin on fibeglass hood, light weight battery, duals, and dropping the front bumper support.
Thats close to 100#s !!!!
Old Jul 26, 2007 | 01:45 PM
02NBMWS6's Avatar
my duals weigh about twice as much as my y pipe setup id guess. why would you expect to lose weight by adding another exhaust pipe?
Old Jul 26, 2007 | 01:47 PM
95 Z28's Avatar
My dumped duals with stainless Magnaflow 4x9s weight about 5 pounds more than my old Borla did.
Old Jul 26, 2007 | 01:56 PM
Phlip00WS6's Avatar
Your going to gain 5-10lbs over the hooker
Old Jul 26, 2007 | 02:25 PM
2000Z28M6's Avatar
I thought since i'm not going over the axle it would be less weight.
bummer
Old Jul 26, 2007 | 02:34 PM
camarokid94's Avatar
here is my thoughts on this as i thought the same. what i will be doing it takin the cat back off and right after the Y put a muffler like what comes with the TD kits. less weight not as loud as the cutouts. i figure should save 20-30 lbs
Old Jul 26, 2007 | 02:42 PM
Ericbigmac83's Avatar
From what ive seen, having dumps before the axle is gonna weigh about the same as a catback depending on if youre going bullets or mufflers. If you go all the way to the back the duals obviously weigh more
Old Jul 26, 2007 | 02:43 PM
Thats gonna be loud as ****
Old Jul 26, 2007 | 03:06 PM
SilverGhost's Avatar
Motorboater
i hate how loud duals are inside the car(had it before) so I have a loudmouth II on the car to keep the exhaust at the bumper but its alot lighter than a typical catback obviously. car is ***** loud through the exhaust, and really f'n loud if when i open the cutout I put right after the Y pipe
Old Jul 26, 2007 | 03:37 PM
TwoFast4Lv's Avatar
I am running 3in "Y" Pipe into a 4in Bullet. As light as you can get and still run in some classes. I am getting ready to run 4in light weight Stainless over the axle to a flapper out the passenger side. When the flapper is closed it will push through a 4in XR-1 12in long Borla and out the driver side.
Basically a controlled version of the standard Borla only all 4in
BTW with just the 4in Bullet it is loud as hell
Old Jul 26, 2007 | 04:11 PM
well the cutouts are right under the drivers and pass seat (i made my own like the QTP setup) and i am pretty sure nothing is louder than that. i ran the open headers and it is about the same loud wise.
Old Jul 26, 2007 | 04:22 PM
Demonicbird00's Avatar
when going from the mufflex catback and TSP ORY tothe duals i dropped
27 lbs
-brandon
Old Jul 26, 2007 | 06:49 PM
2000Z28M6's Avatar
Ok, now im confused.... Will it save weight or not?
Demonicbird what dual setup did you use?
Old Jul 26, 2007 | 07:04 PM
JEB99TA's Avatar
I had tru duals last year and liked them for a few months ... got old real quick with the vibration and noise. I had dynoMax straight-thru mufflers and was dumped before the axles. It might have been a few lbs lighter, but, I doubt there as much difference.
Old Jul 27, 2007 | 12:43 AM
TwoFast4Lv's Avatar
As a few posted the systems I weighed added a few pounds so no savings
Old Jul 27, 2007 | 10:11 PM
ss_girl's Avatar
I dropped right around 30lbs when I switched from a borla to my speed inc duals. A little extra piping weighed alot less then the heavy muffler and tail section.
Old Jul 28, 2007 | 01:26 PM
2000Z28M6's Avatar
I wish I could get a straight answer, will I loose any weight by ditching the catback or not?
Can we agree on this?
Old Jul 28, 2007 | 01:31 PM
JL ws-6's Avatar
Race your car!
I lost about 50 lbs taking the whole Y pipe and catback off, and putting turndowns off the end of the headers
Old Jul 28, 2007 | 05:58 PM
James Montigny's Avatar
Old Jul 28, 2007 | 08:41 PM
2000Z28M6's Avatar
you got jokes.......
