Anyone running MT ET Streets on 16" wheels?
im using these tires also but need some help.
lid, long tubes, ory and cat back with the ls7 clutch and 9" with 3.90s i think i had them at 20psi, i droped the clutch at 3500rpm got a 1.922 at dump 4k and got a 1.897 it was my 1st time out with the et streets ill be going again in 2 weeks and now with the new mods (p&p tb, ls6 intake, sfc, lca and a t/a)
what would be the best way for me to launch?
i was gonna start with a 5k dump and go from their
Originally Posted by waterbug1999
I hear ya... But, it also has to do with weight transfer and suspension set-up as well.
Have you takin off the front sway bar when you run at the track before? I know it helps me ALOT to get the front up and the weight transfered.
#34
so 1badair dumps at 2500 and 02somws6 launches at 5500 and one2run dumps at 4500........so ill add them up devide by 3 and launch at 4100 lol
#35
what psi with the 28s?
Originally Posted by 02SOMWS6
Thats what I launched at with 26" slicks. When I switched to 28" slicks and 4.30 gears I had to raise it up SOM. I launch now anywhere from 6400rpm to 6800 but I'm sure all that will change again when I change my cam. Everyone's car is different so your gonna have to see what works best for you
#38
well i went to the track last night but my 60 still sucks. 1.9 is about all i can get i tried dumps from 3000-4500 and some quick slips at 2500 and 3500 the car boged every time i was gonna try 5k+ but a friend broke his d/s on a stock car on street tires at 2k the same night so i got a lil worried im gonna put my street tires back on and go up again and work on my launch on street tires so i dont where out the slicks but i did get a new pb et and mph
#39
I had some MT ET Streets I threw on my old Salad Shooters last year, I have a M6 3.42 and I could launch off the rev limiter and bog, I was running 13.5 pounds of air, I think I should have put some more air in the tires but I was new to the whole drag radial thing...best I ever pulled was a 1.89 60ft...I bought some Nittos this year so I wouldnt hook as well and hopefully save my 10 bolt, Nittos suck ***** my friend! lol Just thought Id throw that in there.
#40
