Drag Racing Tech
Going to be my first time going to the track
Old Aug 2, 2007 | 10:34 PM
Tdawg's Avatar
Default Going to be my first time going to the track
coming up here in about a week or so i'll be doing my first track run . I'm trying to guess what my times are going to be, maybe you guys can help out, the mods that i have done to my car are on my Fquick page in my sig my RWHP and RWTQ where 368/390 but i also just added a 85mm TB and MAF so it may be a little bit higner. i just need to ad the LCARB and adj. LCR and PHR then i'll be going.
Old Aug 3, 2007 | 10:54 PM
donkey mule's Avatar
Mid to high 12's would be my guess. If you dont do that well dont be disapointed - it takes time to learn a car and the track. Get some good tires and work on your launch. If you do well in your 60 ft you should do well. Post some results when you get them!
Old Aug 5, 2007 | 01:25 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
As mentioned above, chances are your first time might not be what you're hoping for. Remember, we all had to start somewhere. You didn't mention whether the car is an auto or stick. Check out the "First time" sticky post in here for tips, and be sure to post up results so you can get feedback and work on getting better. Have fun!
Derek
Old Aug 5, 2007 | 01:54 PM
Tdawg's Avatar
thanks, i know that it wont be what i'm expecting just really excited to go . by the way its a stick
Old Aug 5, 2007 | 10:21 PM
transamfreak01's Avatar
yeah asme times as posted above.. when you go to the track, make sure you sit out and watch some runs before jumping right into it. and when your going into the burnout box please make sure you dont drive right through it unless you have skinnies. pull past it and reverse into the box b/c otherwise your going to track water all over. thanks a good luck
Old Aug 6, 2007 | 12:04 AM
Tdawg's Avatar
thanks for the info will do, much appriciated
