Drag Racing Tech
Do 28" MTs fit without modifications
Old Aug 5, 2007 | 10:12 AM
Krazy98Z28's Avatar
Default Do 28" MTs fit without modifications
I'm looking to run a 28" tall tire, just wondering if i need to do anything to fit that tire on a 99 SS. I plan on rolling the fenders.
Marco
Old Aug 6, 2007 | 02:18 AM
revtime's Avatar
Mine fit just fine. I have double adjustable LCAs and my 12 bolt shortened 2.5 inches on each side. I have not rolled the fenders or touched either side of the outer wheelwell. I did have to do some clearancing on the inner parts.
The double adjustable LCAs will center the tire in the wheelwell so all you will have to worry about is rolling the fenders.
Old Aug 6, 2007 | 04:56 AM
JL ws-6's Avatar
Race your car!
a 275/60/15 radial will fit with no molesting at all other then a little tap on the lower front part of the wheelwell. Get into the bias ply stuff ans you need more room for the tire expansion.
Old Aug 6, 2007 | 10:54 AM
purdueranger's Avatar
You are correct. Bias ply tires grow in tire diameter and radials grow in width.
M/T say they grow between an inch and 1.5".
Old Aug 6, 2007 | 07:24 PM
ERIK@MASPORT's Avatar
Closed Sponsor Account
say byebye to bump stops also..... I am in the middle of it right now....
Old Aug 6, 2007 | 08:16 PM
JL ws-6's Avatar
Race your car!
the bump stops need to come off for the car to travel enough as I found out, but with teh goodyear radial they did not rub on them at all, neither did the 27x11.5 qtp i ran last year. For a tire much wider, the metal itself will need to be cut off, next time I have the tires off my car I am gonna lop that tab off... cutoff wheel-HO! LOL.
