Quickest/fastest N/A stock bottomend? 10.57 @ 128
Re: Quickest/fastest N/A stock bottomend? 10.57 @ 128
Great runs!! Who did your tuning on it and what are your shiftpoints? I like the traditional split vs the reverse. I see that GM does it with all of their cams so why not use what they spend millions on R&D? Good luck on your future runs, and i like the statement of "it is the quickest fastest for now stock shortblock". I think you said the same thing about the stock internal record and its still there.
Personally, there may be a bit left in the programming, but you lose a lot or gain some. If the cam was much bigger, compression was higher (I'm around 11.0), you've got a power adder, etc., obviously, there would be a lot more in the tuning. I think too many guys are going to "big" on some things (heads, headers, cam, compression). All those things are nice, but a good combo is key. I keep feeling the pull to go "bigger" on something, but will wait until this thing nukes or I finish up what I want to do on the car right now (replace stock carpet, go to some solid motor mounts, play with the idea of 30x9 or 30x10.5 radial slicks, play with the calibration a bit, etc.).
I've hosted RUQWIKR's video's for anyone who wants to check them out...
Here are the URL's:
http://www.coffeyracing.com/media/dw_10577.wmv
http://www.coffeyracing.com/media/dw_incar.wmv
Right click on the link and choose "Save target as..."
Enjoy!
Here are the URL's:
Enjoy!
Nice new ET Dave!
Did you get a cage into the car yet?
You used to be like 3100 raceweight right (for the guy who asked).
I like seeing a guy up here in the MW run that good, your best DA's are like what we get in Chicago.
Are you going to MM7?
Nice new ET Dave!
Cage is in (6-pt moly). What date is MM7 this year so I can get it in the calendar? On the weight, I think a lot of guys "over" estimate how heavy their cars are. I've weighed it on two good scales (Stanton and Norwalk). Take care.
Also, a big thanks to George C for hosting the videos for me. The in-car was off at an angle because I could not find my remote control for the camera after I was strapped in and ready to go, so, I reached around to turn it on. BTW, it was a 10.59 run, I think the one on DR's. Take care.
