rear glass delete kit?
I just had to trim it. I'm not sure if its actual mar-guard (I may be mis-using the phrase) but its pretty tough compared to the stuff I had on my last car with lexan windows, the guy who made it mentioned mar-guard I never heard of it prior to that.
Post up some pictures when you get yours on the car for us.
I have made misc side windows out of lexan with a heat gun and the stock glass but I didnt want to blow a sheet of 3/16 if I screwed it up. I cracked the back glass trying to get it out and he volunteered to take the glass out (my method was going to be a BFH) and make the window when I was on my ultra-lightning bine last winter. Unfortunately all the stuff I planned to do I didnt get done and its heavier then when I started
but kp you said you did get sides to work before? i was wondering if i could get them to work with stock regulators/motors and rivits? (think thats what holds them in)
Different car I made the side windows for, third gen but they didnt roll up and down.
Lexan wont work too well with the regulators these have, not much weight to be saved either. But if you gut the doors and regulators and do stationary lexan windows with a frame you can save a bunch
Well according to there website, the rear is anywhere from 325 to 520 depending on the thickness.
Just remember, you get what you pay for. You can probably get regular lexan for cheaper, but it wont have a good coating on it like the speedglass.
WEIGHT COMPARISON
The most valuable advantage of SPEEDGLASS for racers is the tremendous weight savings, not to mention being
shatterproof and extremely scratch resistant.
Following is an actual weight savings comparison for some popular race applications. Weight savings can vary
depending on thicknesses of SPEEDGLASS
windows used. The following comparisons are factory glass vs. a full set of 1/8" SPEEDGLASS windows, common for
most race applications.SPEEDGLASS is the best weight savings per dollar spent for any steel-bodied race car. Please contact Percy's
High Performance, Inc. or your closest dealer for ordering information!
Application Factory Glass Weight SPEEDGLASS Weight Weight Savings
79-93 Mustang 71 lbs.,,,,,,,,,,,,,,,,,,,,,,28 lbs..........................43 lbs
82-92 Camaro 108 lbs.......................31 lbs..........................77 lbs
93-01 Camaro 96 lbs.........................32 lbs........................64 lbs
