Question for Madman....
the DIY was is to Place a 1" white line on the tire and mark it's position make one full revolution with the tire, take a tape measure and measure the ditance.
At large Event's you can usually buy matched tires from the MT trailer
No problems. Looking back on what I wrote last night it did not come the way I ment it. One to many beers. sorry LOL
We can go over the rest then. I have faith you can make it hook
BTW Many times they have the number on them in white across the tread when you first get them
Hoosier does mark theirs at the factory so they can be matched.
You can buy a tire tape and just measure them or a piece of string and mark it (metal carpenter tapes dont work well, not made to go around curves) then just air the smaller one up a little at a time (putting it out in the sun speeds it up) until it gets to the right size. Then put both tires at the same air pressure and check again, if its with a 1/2" or so just leave it. Only works with new tires.
MT has the procedure on their website under tech stuff. Also nevr ASSume just because the same number is written on both tires they are the same when they are mounted on your wheels.
Ok that would explain it. I am using hoosiers and have seen Nitto's marked also
They were off quite a bit on the first few batchs we got last year The Best V8 Stories One Small Block at Time
As well as they hook I don't think I'll ever hassle with slicks again.
I just use drag radials because I have to in some races. Maybe I'll grow to love them some day
I just wish they would make a 305 something that was 28.5" tall..
It is Nitto's new drag slicks
