Does Octane booster \ running higher octane fuel do anything?
anywho, i need all the help i can get, would running like a 96 octane or octane booster do a damn thing unless your car was tuned accordingly?
anything else i could do to get ready? im just gunna go underneath make sure everything is tight, and filled up. not sure what else there is.
its 99% a street car so im not pulling seats or anything like that.
how much fuel do you guys run? im thinking 1\4 tank, and bring a spare jerry can.
the octane booter does nothing, well if you have 93octane in the car it will bump it up to 93.5 so its not worth it.
just get 93 all youll be fine, only time you need to go higher in octane is if you are FI or have higher CR
start out w/ 20psi in the tires, and go from there, launch the car from 4k to start, if you hook then bring it up higher the next time. bump the tire pressure up as high as you can in the front
-brandon
tires are 275\40\17 bfg drag radial. about 2000 miles on em.
4.11 gears. check out my car domain site in my sig for a detailed list of mods. let me know what you think. and how do you think id do?
is the stock rev limiter still there?? if not shift the car at 6500 if it is your losing alot of time cause of the limiter and need it bumped up.
-brandon
my rev limiter is set to 6600 and i shift at 6500. is that about right given my horsepower and torque curve?
If the engine does not need or require higher octane then the higher octane will help it.
If you have a pump gas motor but its built for the bottle it will run a little slower on the race gas on the motor but needs the race gas for the bottle.
Leave the octane boosters for the ricers.
