Drag Racing Tech
trouble w/ brackets
Old Aug 20, 2007 | 12:06 PM
tee-boy's Avatar
Default trouble w/ brackets
Went to put relocation brakets on this weekend. Noticed that the only way they will slip over the stock axle's bracket is if you take off the bracket that holds the brake lines in place. This ain't in the instructions. What's the fix here?
Old Aug 20, 2007 | 12:11 PM
Matt D's Avatar
Retired Street Racer
You have to take that brake line bracket off. Weld the relocation brackets on, and then bolt the brake line bracket back up.
Old Aug 20, 2007 | 05:09 PM
UMI Performance's Avatar
The bracket just needs unbolted, install the relocation brackets then cut the bracket to fit or bend it. Hold the bracket in place using a control arm bolt.
Hope that helps!
Ryan
