LT1 60ft Improvements?
and plz no "Buy an LS1...that will fix ur problem." comments
thx tony
you gave me A headache...
But to answer your question if your car had any kind of horsepower it would 60 foot decent.
Ok so it sounds like you are still spinning? what are the reat of the numbers?
BTW I have done as well as 1.5x 60ft times with the front wheel off the ground on ET Street Radials 275/40-17s
1-still spinning
2-a stock stall converter and/or low numerical gearing doesn't allow the car to get into the powerband early, thus the sluggish 60 foot times.
My Formula only goes 2.05 60 foot in the summer, and I know it hooks with the M/T sportsman pro tires I run. The stock converter and 3.23 gears in the rear end are the reason it's slow off the line.
As mentioned above, a gear swap and/or converter swap will help lower the times, but remember that it will also put more strain on those parts versus a stock set-up. The 10-bolt can use a girdle cover for added strength, and if your transmission has a lot of time on it, consider a rebuild or beefing up the internals before doing the converter.
Good luck!
Derek
I was cutting 1.6 short times with a bolt-on car, 2800 vig and 3.23s
it takes more than a tire to make you hook, and foot braking and stalling to 1500 doesn't appear to work, you need to try different techniques until you find what works
if you have $ to spend a converter is an unbelievable upgrade
headers then gears imho
if you're not hooking you're not gonna break your 10-bolt.
I read somewhere that those clear altezza style taillights add .2 to your sixty
lol Last edited by fast; Aug 23, 2007 at 10:14 AM.
thread starter guy have you undone your front sway bar links (removed bar preferred for weight)?
it helps a little
lol...ANYWAY
A nice sized converter will do the trick.
R/T -.076
60 2.083
330 5.8
1/8 8.817
mph 81.52
1000 11.442
1/4 13.659
mph 101.81
i figured the way i was launching was the best way... i figures considering how lengthy my burnouts were i wouldnt have to worry about spinning... but i think i may be spinning a tiny bit right off the line but im not certain to be honest... i kno i can buy a stall and some gears and i plan on it this winter but from wat i heard u can get these cars on DR's in the 1.8's - 1.9's all of my other runs were 2.1's except this one run... i dn maybe i should try launching at idle???
