Drag Racing Tech
Seat/harness mounting...
Old Aug 27, 2007 | 10:20 AM
Phil99vette's Avatar
7 Second Club
Default Seat/harness mounting...
I'm in the middle of mounting my kirkeys in my LSx powered mustang and need some advice. The seats are being mounted with 1/2" CM tubing terminating in 1" CM tube with a piece of CM on the end making a mounting surface. I'm thinking about using 3/8" grade 8 bolts.
The driver seat is mounted on the left side to the rocker bar of my 25.5 cage and to the rockerbar/driver bar intersection. I have a tab welded to the rocker bar for the left harness mount. The passenger side is where I need alittle help. The front has a decent section for a mount but the driver seat right rear has really no provisions. The only thing I can think is to use a 1/2" tube with a bend in it to get around the seat and tie it into the subframe. I could mount it to where the sheetmetal factory seat mounts and have a bar with only a small bend it in. The seat support bar will go to the funny car cage and just have a flat piece of CM to bolt to the seat.
Harness mounts have the same issue The lower right lap belt gets a tab on the rocker bar, the upper belts go to the funny car cage and get 2 seperate tabs, the crotch strap gets a small tab on the floor where the factory seats bolted down. I can't figure out where to mount the tab for the right lap belt. Its right in the area of the trans tunnel and I'm not sure if the sheet metal is strong enough in that area. Any help or pics is greatly apprecated.
Old Aug 27, 2007 | 11:25 AM
JL ws-6's Avatar
Race your car!
Where did the factory seat belts mount to? If you can use that I would.... it's safe to say that would probably be strong enough.
Different car I know, but I mounted my 5 pt harness to the factory seat belt positions on the floor, 2 seperate tabs on my rollbar and the crotch strap is attached to the same metal the seat is attached to the floor with (the actual floor of my car where the rear 2 studs are, I used those studs to mount the seat on the bottom)
Old Aug 27, 2007 | 11:45 AM
7 Second Club
I'm going to check the factory seats, I don't see any place on the floor where they bolted the inside seatbelt mount. I wonder if I can run the driver bar under the seat and use a small stub to the sub frame to support it.
Phil
Old Aug 28, 2007 | 10:08 AM
7 Second Club
Here is what I ended up with:
There is a piece of 1 1/2" CM on the back of the seat with 1/2" tubes going to the seats.
Old Aug 28, 2007 | 11:10 AM
JL ws-6's Avatar
Race your car!
That should be fine. Looks more solid then the mounting on mine, and my seats don't move at all even if I stand in them.
