should i go th350 or glide???
With the Th350, what stall? what gear? to make it even quicker. Any recommendation appreciated. Thank you.
there is a bit of an advantage to getting off the line with a th350, but after the first 30-40 feet that advnatage disappears. with a god stall and the right tire/gear combo you can cut close to the same short times with the glide.
the glide is so much lighter both physically and internally that whatever minor loss there could be in the first 40 or so ft will more than be made up for in the following 1280ft
That sounds about like what I was thinking. A glide has the least amount of power loose in an auto car.
