Drag Racing Tech
M6, tires?
Old Sep 6, 2007 | 03:39 AM
blk99camaro's Avatar
Default M6, tires?
Just wondering what tires all you M6er's are running on the strip. I have a LS1 with boltons, cartek clutch, moser/strange 9"w/ spool,4.11's, 35 spline axels. My best so far was a 12.7@114, that was with the stock 10 bolt and I had a good bit of wheel spin off the line and through gear changes, that was with nitto 555r's. Over the winter Im putting more cubes under the hood as well. I have been considering the M/T ET Street, the non radial, but I do not know much about them. Do you all run tubes in them? Im open to all suggestions at this point. Thanks
Jon
Old Sep 6, 2007 | 08:34 AM
SlickVert's Avatar
My best was on MT 28x10.5S
Old Sep 6, 2007 | 09:58 AM
Were these ET Streets(non radial)? I have heard the radials dont like the shock of the clutch dumps off the line and were better for the Auto cars.
Jon
Old Sep 6, 2007 | 10:13 AM
SiL3NtXWS6's Avatar
stiff sidewall slick is what he is referring to.
Old Sep 6, 2007 | 10:23 AM
Demonicbird00's Avatar
i got my best w/ the MT DRs 275/50/15
-brandon
Old Sep 6, 2007 | 07:23 PM
GC99TA's Avatar
-brandon
You went 1.59 and 1.49 on a 275/50/15 drag radial? Wow. The best I can cut with the same tire is a 1.84. Could you share your suspension set up and other details like launch RPM, clutch dump or slip? Thanks.
Old Sep 6, 2007 | 08:54 PM
i have the DMS suspension, lowered. launching at 5k.lil slip then dump
-brandon
Old Sep 7, 2007 | 01:52 PM
GC99TA's Avatar
-brandon
Thanks. I think I need to try and slip my clutch a little to reduce the shock on my tires.
Old Sep 7, 2007 | 03:07 PM
smokeum99ta's Avatar
26x10/15 ET Drags, 1.35 60' on nitrous, 1.51 on motor. Me and my friends never had any luck with the drag radials on stick cars. Go get some slicks since you have the rear to handle 6k launches and your times will drop. Just hope nothing else breaks (u-joints, driveshaft, trans output shaft, clutch, etc...).
Old Sep 7, 2007 | 03:37 PM
GC99TA's Avatar
Yeah, I already twisted a stock aluminum driveshaft in half once and broke an output shaft, both on ET Streets (bias plys). I now have a D&D T56 with the Viper output shaft and Denny's N20 ready driveshaft. I'm sure I'll break my 12-bolt next or explode my clutch.
blk99camaro, sorry for the hijack
EDIT: Just realized you were probably responding to the original poster. Now I really feel like a hijacker.
Old Sep 7, 2007 | 04:33 PM
Bye bye 12 bolt posi, thats next. You name it i've broke it launching the car. blk99camaro should be alright when it comes to the rearend w/ the 9inch.
Old Sep 8, 2007 | 04:28 AM
I doubt I will have too many problems except the trans. The rear has all the billet goodies like the yoke,spool, bearing caps. Its a little overkill for my setup right now but I got it like that to have room for more power upgrades later on. I already have a cromoly d/s. I have UMI 3pt SFC's, LCA's, TA with relocation mount and d/s saftey loop, the next weak link is the tranny and I shoulnt have any problems with the cartek clutch.
For those of you running the ET streets do you all run them with tubes? I know that they will lose air slowly without them but like I said this will be driven to the track with the street tires on and changed to the drag tire.
Jon
Old Sep 8, 2007 | 09:05 AM
Jon
I agree, you have plenty of rear. As for the et streets, you can run them either way you like. They lose air but it not like they will go flat in an hour. It'll take a few days. I'm not a big fan of tubes since I pinched one at the track and almost wrecked. But that could just have been an freak event but none the less i'll never use tubes for drag racing again.
Old Sep 8, 2007 | 01:43 PM
1nastyss's Avatar
Whats up Jon, i am going with the 26x11.5x15 hoosier QTP's...form what i read, they seem to be hooking a little better, plus their the same price
