Adding ground clearance with QA1s??
Also is it normal for the spring seat nut and the jam nut to be hand tight once spring tension is removed?
I'm gonna guess about 1/2 an inch on the collars to start, that will probably get you close.
I would go a Half inch at the shock. They are ACME 1/8th inch threads so four turns is a half inch at the shock. It should come out to 3/4 or so at the wheel well.
BTW there is a point where it lifts ALOT more then you think
