Drag Racing Tech
LCA relocation brackets
Old Sep 11, 2007 | 05:29 PM
camar0corey's Avatar
Default LCA relocation brackets
Do these drastically increase traction? I have spohn cromoly LCA's, adj. panhard rod, adj. torque arm, and I'm cutting 2.4-2.6 sixty foots. I know a good chunk is probably driver error, but I know on 275 street tires I should be doing better than that.
Will they benefit me even if I'm still at stock height? Do they affect cornering ability or no?
I don't know much about them, but I figure if it will help this thing hook......
The weld in's are less than $100 usually right? Recommendations on who's to run, or are they all just about the same? I'd probably do the weld ins.
Thanks -Corey
Old Sep 12, 2007 | 11:06 AM
slow trap's Avatar
i doubt you will see a drastic improvement but you should notice an improvement.i have the umi weld ins.
Old Sep 12, 2007 | 12:49 PM
pddye's Avatar
a 2.4-2.6 60'? Just get some better tires. Before i had any suspension work done i was cutting 2.0 60's or better which is not good by any means.
Old Sep 12, 2007 | 01:06 PM
WE TODD DID's Avatar
It will increase your 60' times, but tends to make cars unstable on the big end due to changing the instant center.
Old Sep 12, 2007 | 01:10 PM
Z06kern's Avatar
Thanks -Corey
I have a set of the BMR weld in brackets for sale. $65 shipped if you are interested.
https://ls1tech.com/forums/lsx-parts-sale/781909-bmr-lca-relocation-brackets-sale.html
Old Sep 12, 2007 | 02:23 PM
gator's 99TA's Avatar
your problem is tire, not relocation brackets. they do help but you need traction first. put a tire on it.
Old Sep 12, 2007 | 06:13 PM
So would they also affect say if I went out for a top speed run? Or do they make the car unstable while braking? Please explain the unstable part to me.
Old Sep 12, 2007 | 06:55 PM
Sluggish's Avatar
Get better tires, My best 60ft is a 1.87 on street tires Kumho MX's. Thats with no suspenision, stock gear, 6 speed. Tires and practice launching.
Old Sep 12, 2007 | 08:16 PM
Matt D's Avatar
Retired Street Racer
They will help with traction. My car is as stable as can be on the top end. No problems.
Old Sep 12, 2007 | 08:56 PM
Twin76mmTA's Avatar
+1 on tires!
Old Sep 12, 2007 | 09:25 PM
Gary Z's Avatar
Originally Posted by gator's 99TA
Your problem is tire, not relocation brackets. they do help but you need traction first. Put a tire on it.
I agree that your problem will not be solved by relocation brackets but you would risk breaking your 10-bolt with sticky tires. You should be able to occasionally cut 1.9-second sixtys with your car as is - 2.0 seconds should be easy. Forget about hooking, you need practice.
Old Sep 13, 2007 | 10:35 AM
Yeah I hear you on the practice part. Sucks I'm in the middle of all the tracks, gotta drive 2-2 1/2 hours to hit a decent one.
Typical FL issues too, I used to have a road where I could go out and try, but what do you know, more developments, the cops sit out there now and tell people to take it somewhere else..... what do you know on a Thursday night there isn't anywhere to take it.
