Need help getting my 60' down
The suspension is mostly stock except for Bilstein HDs and an Edelbrock torque arm. I've tried adjusting where I launch at and found that it launches better when I leave at about 1500 and stand on it. Ideally, I would like to get the car to go 1.60s. Any help appreciated.
Derek
I think a looser stall (best to go by the dyno sheet) or N20 would wake your car up nicely
Cam specs are .598/.598 244/244 114. The car is set-up more to be a street car than an all out drag car, but I'm thinking it should do better than 1.80. I was thinking the same thing with going to a looser stall, maybe a 4000 or 4200 to help it get out of the hole. I'm leaving on the foot brake so it's obviously not seeing 3600 when it flashes.
I'd get the converter redone, and look into trying to get some weight out. If you can get the car to 3600, I am sure it's gonna wake right up.
The brackets and control arms are a good idea too, you'll eventually need them, and a set of m/t radials too if you aren't already on a tire like that.
I bet if you really start looking into it, there is 200 lbs you can remove and still have every power thing in the car. At least in track trim (wheels swapped, that type of thing)
Sounds like you have a nice set up there, the only thing I would change right now is the weight and take it from there. Nice work so far man!
I would take it to Mike and Ron, but for some reason every time I go up there I'm eating romen noodles for a couple weeks after and my wife won't talk to me.
Next on the list, re-stall and weight reduction. Think it's about time for the subs to go anyways. Getting too old for that stuff. Only problem is that's right where you want the weight. Guess the 12 bolt makes up for it.
Here's a pic of the car in race trim with the car launching. I am running MT DRs here.
The 12 bolt is quite a bit heavier than a 10 bolt (70-80#s?)
Keep us posted and Good luck!
