Drag Racing Tech
Who makes the ABS delete block?
Old Jun 3, 2003 | 07:49 PM
Phate's Avatar
Default Who makes the ABS delete block?
Thanks!
Scott
Old Jun 3, 2003 | 08:32 PM
Big Rick's Avatar
Default Re: Who makes the ABS delete block?
I think it is Billingsley Racing. They're a sponsor on this site.
Old Jun 3, 2003 | 08:38 PM
Phate's Avatar
Cool, thanks!
Old Jun 3, 2003 | 11:47 PM
zturbo's Avatar
Last I heard Jay Billngsley did have these.
Steven
Old Jun 4, 2003 | 10:37 AM
smokinHawk's Avatar
i saw a few guys were they didnt use a block, just had the fronts to the line lock then the rear to the rears.
least i dont think they had one
Ive been thinking of ditchiching abs when i get my 12 bolt
any comments about doing this to a daily driver?
Old Jun 4, 2003 | 11:07 AM
Phate's Avatar
I have had the ABS disabled for quite some time (lost it when I went with the 9" and spool).
I never noticed the loss of ABS at all, even driving around with skinnies on the car all of the time.
Old Jun 4, 2003 | 05:05 PM
Phate's Avatar
I ordered one of these delete blocks today...should get rid of the rest of the heavy ABS stuff!
Scott
Old Jun 4, 2003 | 08:28 PM
B18B1LS1's Avatar
From Billingsley? How much?
Jeffrey
Old Jun 4, 2003 | 09:51 PM
Phate's Avatar
Yep, got it from Billingsley. It was $169 plus $9 for shipping.
Old Jun 5, 2003 | 11:52 AM
SMOKINV8's Avatar
Scott
I thought it was like 5-10lbs at most? What's all that stuff really weigh in at?
Old Jun 5, 2003 | 02:18 PM
zturbo's Avatar
the abs deversion block computer thingy (not sure its exact name) weighs a ton itself alone.
Steven
Old Jun 5, 2003 | 02:42 PM
Phate's Avatar
I was under the impression that the ABS brain/solenoid was ~8-10 lbs. Maybe I am mistaken though...I will weigh it when it is off of the car.
Old Jun 5, 2003 | 04:13 PM
Phate's Avatar
According to the Colonel's weight reduction list (a few posts down), the ABS is listed @ 9lbs.
Old Jun 5, 2003 | 04:21 PM
Fenris Ulf's Avatar
Steven
That's the block on the driverside next to the fuses right? Is there anything else I can yank after removing ABS? By the way, I know that block weighs alot more for LT1 cars.
Old Jun 5, 2003 | 05:30 PM
Phate's Avatar
You can also yank out the ABS sensors and the cut the plugs that connect to them!
Old Jun 5, 2003 | 05:54 PM
Fenris Ulf's Avatar
Thanks Scott. Guess I can snag the fuses for ABS while I am at it
Old Jun 5, 2003 | 07:15 PM
Phate's Avatar
Never would have thought of that one...
Old Jun 7, 2003 | 08:45 AM
chevyguy3's Avatar
the ABS block on LT1 cars is 9lbs also. on traction control LT1 cars it is 18lbs though, not sure about LS1s with TC. even if it was 0 lbs it would still be worth ripping out of there for the extra engine bay space
Old Jun 8, 2003 | 10:49 AM
Magnus's Avatar
LS1TECH Sponsor
Whats the difference between using Billingsleys brake setup vs just using a porportioning valve alone?
Old Jun 11, 2003 | 03:22 PM
1moreblackta's Avatar
What is daily driving like without abs? ever lock up? panic stops?
thanks..
matt
