Drag Racing Tech
What launch speed?
Old Oct 4, 2007 | 09:04 PM
94lt1m6's Avatar
Default What launch speed?
My mods are in sig. What RPM's should i be launching at with the 225 DRs i have on it.
Old Oct 4, 2007 | 10:49 PM
slowbrakiller's Avatar
whatever feels best. every car is different
Old Oct 10, 2007 | 03:22 PM
chrismorales75's Avatar
I'd try with the most you can hold the brake down and rev the motor too and then floor it, keep the tires and burnouts the same and lower the rpm if it spins a little each time until it hooks, BTW 225? why such a skinny tire?
Old Oct 10, 2007 | 03:43 PM
Jakes Dad's Avatar
Why do you have DRs on a car you've never raced?
An old man and his dog
Old Oct 10, 2007 | 04:08 PM
Gimp98TNT's Avatar
That was a useless post.
Back on-topic, i ran a 235/60/15 MT DR for a little while when i still had a M6. I could leave around 3000rpm with a quick clutch release, not a all out clutch dump. This netted me 1.59 60's. I was only making about 380rwhp at the time.
What brand of DR's are they, that'll make a big difference. I would start low around 2k and work your way up till you just get a little spin so you dont bog. That should net you the best 60 ft/ET.
Old Oct 10, 2007 | 05:22 PM
He runs an auto with a 3500 stall, I doubt he'll bog and why post techniques for leaving with a stick shift?
Spinning the tires a little won't result in the best 60ft.
Whole point in an auto without a transbrake is to try to preload the tire before you leave.
Hold down the brake rev up on the converter some then gas it and if it spins try dropping the rpm you stall up to a little at a time.
Old Oct 10, 2007 | 07:11 PM
Gimp98TNT's Avatar
oops i seen M6 in the one car in his sig, My bad. Disregard.
Old Oct 11, 2007 | 12:11 PM
Matt D's Avatar
Retired Street Racer
And you don't even have a ******* car to race. All you do is troll this site and try to put in your worthless two cents into every post.
Old Oct 12, 2007 | 08:09 PM
Ha-Ha
Old Oct 12, 2007 | 09:08 PM
carfax's Avatar
stall up the tranny and use pedal control to not spin on the line. thats all i can tell you. every car is different so you have to use trial and error on the launches.
Old Oct 12, 2007 | 09:11 PM
motownZ's Avatar
thats funny
Old Oct 12, 2007 | 09:14 PM
waterbug1999's Avatar
I have been using MT DR's 255/50/16, which yours are a little narrower, but you got less power. If they prep the track good and you do a descent burnout, I dont see any reasons that you shouldnt hook. But key is track prep and a nice burnout.
You are going to have to try different RPM speeds. Its prolly gonna be hard to look at the tach and watch the light, so the 1st few times, screw the light and look at the tach and pay attention to the sound of the motor and let her ripp... Thats the way I started and can pretty much tell by the sound of the motor.
But, for me, trying to revv the car up as high as I can without rolling thru the beam seems to net me my best 60'.
Old Oct 13, 2007 | 01:10 AM
Do they make a 2 step for ls1 cars?
