Drag Racing Tech
Front Wheel Studs
Old Oct 11, 2007 | 02:45 PM
Twin76mmTA's Avatar
Default Front Wheel Studs
What length is everyone running in the front with shank style lugs so they extend out a bit?
Who did you buy them from? A few of mine are bent and it's been so long i don't remember witch ones i need i know they are 12mmx1.25.
Old Oct 11, 2007 | 02:53 PM
xpndbl3's Avatar
3.25" from ARP
Old Oct 11, 2007 | 02:57 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
damn 3.25 for the fronts?
I'm 99% sure i have the 2.5's from arp on the front of mine.
Old Oct 11, 2007 | 03:27 PM
cainsw's Avatar
I have 3.25 ARP's all the way around on mine. ARP is very proud of those things! $120 worth of wheel studs plus another 60 for open end lug nuts
Old Oct 11, 2007 | 07:28 PM
xpndbl3's Avatar
doubt you have 2.5s on there, my moser rear came with them and they're not long enough to pass tech IMO, the threads BARELY pass the weld rim.
Old Oct 11, 2007 | 07:34 PM
SScam68's Avatar
I have 3.25, couple of threads past shank.
Just buy the longest ones and cut em down if need be.
Old Oct 11, 2007 | 08:16 PM
JL ws-6's Avatar
Race your car!
I haave the 3.25 ones, and tehy stick out of the end of my lug nuts a touch more then the dia of the lugnut itself. This is with Bogart's and the standard spacer they weld to the inside of the wheel to clear the stock brakes, and with summit open ended shank style lug nuts.
Old Oct 11, 2007 | 08:39 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
I think the OP means length of the studs for the front.
My rears are 5/8ths
Old Oct 13, 2007 | 09:13 PM
chrismorales75's Avatar
I believe or it used to be your threads must stick out at least 1/2 the diameter of the stud, i.e 1/2" stud must have 1/4" thread showing past the lug nut.
Also remember wheels like prostars and draglites are much thicker in the center than a bogart or Alumastar rims.
Old Oct 14, 2007 | 02:13 AM
TwoFast4Lv's Avatar
Running 2.5 ARPs on all four corners and they are more then enough to pass tech with Bogarts and front spacers. Only like $50-60 to!
Old Oct 14, 2007 | 08:22 AM
joelster's Avatar
With weld draglites or pro-stars you'll need the longest arp studs. The rims are extremely thick in the center. For tech, the threads must engage into the hex portion of the lug nut. They do NOT have to stick out past the lug nut. I'm pretty sure they must engage the width of the stud itself into the hex portion, someone with a rulebook handy will chime in soon.
