Drysump Oiling Vs Wetsump + Accusump
Drysump
wetsump/accusump
wetsump/ 2 accusumps
can an accusump really replace a drysump when the only real concern is oil starvation? Already have a vacuum pump for the rings
as far as i can tell this are the pros and cons of each please feel free to add.
Drysump:
Pros:
little to no parasitic loss from crank moving through oil
adjustable oil pressure
more availalbe oi
if sized correctly can pull vacuum to seal rings
added ground clerance
Cons:
takes up a lot of room for pump and tanks
COST
Not Legal in all Classes
Accusump:
Pros:
Added 3 extra quarts oil protection ( 6 quarts if 2 are used)
compact in size
1/10 the price of Drysump system
Only need to plum 1 feed line
ability to pre oil the system
No class restrictions
Cons:
No vacuum for crank case if used alone
Crank still has to move through oil
Big pro, when the rods go boom, the oil is in the tank, not in the pan with a big hole in it. Priming takes 1 minute to pull belt off. You can see the condition of oil easier. Holds more oil, lasts longer, less maintenance.
