Drag Racing Tech
Madman...Can you look at this
Old Oct 15, 2007 | 12:23 PM
N20Dave's Avatar
Default Madman...Can you look at this
Brian, here is a vid of one of the better launches with the new G-force 5 speed and Soft-lok, lifted at the end. 60' was a 1.55. I haven't started messing with the clutch yet. 3* pinion, 4* LCA, QA1's 3 clicks from soft rear, 4 clicks front soft front, BMR drag bar preloaded for driver weight, 28x13.50 QTP @ 11.5psi, 7000 2-step launch. Any suggestions where to go now? Thanks.
http://videos.camaroz28.com/video/d2...c800d2dbc1.htm
Thought I would open post this as others could benefit.
Dave
Old Oct 15, 2007 | 07:12 PM
chrismorales75's Avatar
Little tire spin huh =) loosen the front shock, also looks like your car moves to the left in the burnout, preload the right side more with the anti roll bar.
Old Oct 15, 2007 | 08:49 PM
daniel6718's Avatar
id say loosen up th front for sure... im no suspension expert though
Old Oct 15, 2007 | 09:03 PM
Ben R's Avatar
Post clutch-info.
Old Oct 15, 2007 | 10:22 PM
ty_ty13's Avatar
7 Second Club
take 3 grams off the clutch and try again.
Old Oct 16, 2007 | 06:08 AM
MADMAN's Avatar
LS1Tech Sponsor
Loosen the clutch some and tighten the rear shocks 4 clicks.
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 16, 2007 | 07:49 AM
N20Dave's Avatar
Thanks. Clutch is locked up tight, 10 turns from base each adjuster, no counter weight. I wanted to get it going straight first.
Old Oct 16, 2007 | 05:59 PM
flyinZ's Avatar
Might just be me, but that tire PSI, seems low...
Old Oct 16, 2007 | 07:17 PM
TINKRD's Avatar
what type of clutch is it? a slipper?
Old Oct 17, 2007 | 08:58 AM
N20Dave's Avatar
It seems to like that pressure but that is 11.5psi hot.
Clutch is a McLeod softlok adjustable. You can adjust base pressure and counterweight so it is like a slipper.
