Drag Racing Tech
Hoosier Dot drag radial
Old Oct 15, 2007 | 02:11 PM
LS1 BU's Avatar
Default Hoosier Dot drag radial
Anyone have experience with these. I was gonna run the 275/60/15 ET Street radials but the tread with is only 9.2 wide. The same size Hoosier is 10.0 inch on the ground. My tire choice is between the 275/60/15 hoosier and a 28/1050/15 ET Drag stiff sidewall.
Old Oct 15, 2007 | 06:33 PM
chrismorales75's Avatar
I M/T is the best drag radial out now, people run low 8's on that tire, it works best with auto's.
Old Oct 15, 2007 | 08:22 PM
LS1 SPEED's Avatar
We do have good experience with the M/T, but as mentioned the 275/60 is narrow. I metioned to him people having good results with the Hoosiers.
Bro I say go with the stiff ET Drag though since you have 2 sets of wheels
Old Oct 16, 2007 | 07:04 AM
DOTracer's Avatar
I have to chuckle when people spew crap about M/T's being the best when they haven't even tried the Hoosiers.
I've run the M/T's for years and just got my first pair of the Hoosiers. After the first few initial runs, I don't see myself going back to the M/T's anytime soon.
yea, just keep running the M/T's...there's nothing better out there...just keep your head in the sand. Technology never improves and there's nothing that can come out to improve on what M/T has now.
If this were all true, we would all still be running on M&H's from the early/mid 1990's, back in the early days of fastest street car racing.
Old Oct 16, 2007 | 09:12 AM
Pimpium57's Avatar
I love the Hoosier DRs. I've ran bigger before, but the only pair I have at the moment are the 315/17s on a stock 17" rim. H/C converter car, full weight, BMR/UMI/QA1 suspension doing a small burnout on dry pavement (no VHT, etc), I can leave on the street at WOT.
I've tried my buddies 17" M/T DRs on the same road in similar conditions and they can't hold the same.
Old Oct 16, 2007 | 09:35 AM
joelster's Avatar
<---Hoosiers here and love them.
Old Oct 16, 2007 | 07:50 PM
sixvi6-camaro's Avatar
I decided to go with the Hoosiers myself. I have the 275/50r15's but I just got them and won't be running them until next season. I figured for my bolt on car I'd have no problem hooking on a decent DR and I really went with hoosiers because they are light compared to MT DR's... My buddies MT DR's 275/50's weighed in at 32 lbs each tire. I just weighed mine and these Hoosiers weigh 22 lbs each tire. 10 lbs of rotating weight is a ton of savings.
Old Oct 16, 2007 | 08:31 PM
TwoFast4Lv's Avatar
we have gone as fast as 10.4x@13x on them lifting the tires.
this is with the P335/35R17s
I just wish they made a size I could use for the shoot out!
Old Oct 16, 2007 | 11:48 PM
Are you talking about the hoosier quick time dot pro tire, because I never heard of a hoosier drag radial.
Open up any Jegs or Summit and look... Hoosier has had them out for around a year now. Here is pic of mine.
Old Oct 16, 2007 | 11:49 PM
I didn't even know Hoosier made a drag radial =/
I might go with a Hoosier quick time pro dot either 28x14.50 or 29x14.50.
Old Oct 16, 2007 | 11:50 PM
95 Z28's Avatar
^^They're pretty new I think.
EDIT: goddamn you guys with your quick posting
Old Oct 16, 2007 | 11:51 PM
How is the compound compared to the M/T? is it softer or harder?
I was considering drag radials for my car but the compound is so soft I can't see them lasting very long.
Old Oct 17, 2007 | 12:00 AM
I honnestly don't know how they compare to an MT DR.. I just got the tires yesterday and before this I was running ET street bias ply's on stock 16" rims. All I know is they are a hell of a lot lighter than MT DR's. They do seem very soft but I'm not too concerned as I'll only be running these at the track and just an occasional drive on the street.
One more pic..
Old Oct 17, 2007 | 12:27 AM
Is one side of those blackwall? I am not cool with big white letters on my tires
Old Oct 17, 2007 | 01:05 AM
TwoFast4Lv's Avatar
They are not that new we ran them all last season.
This is Marks Car off the Hoosier site on his way to a 10.4x pass
Old Oct 17, 2007 | 08:48 AM
Yeah white letters on one side.. blackwall on the other.
Old Oct 18, 2007 | 08:24 PM
rpm4lalo's Avatar
Sent PM to Ellis about the rear tire/wheel combo on the TA pictured above. Looks like ZR1 17X11 rear 50mm offset with 335/35/17??? Any body else know more on the set up? Looked on Hoosier's site could not find a "Mark" or a link to him.
Old Oct 18, 2007 | 09:59 PM
TwoFast4Lv's Avatar
Go to the Drag racing section. Then click on Photo Gallery and he is fthe ourth pic down on the right side
Specs sent
Old Oct 18, 2007 | 10:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
28x10.5 stiff sidewall ET Drag ***.
If you run dr's I would run 325's.
Old Oct 18, 2007 | 10:39 PM
bowtierodder's Avatar
will these fit without major bfh?.... the m/t's i mean
