Whats the MIN in sus mods for building a low buck setup?
Bone stock will work fine. As camscam02 said, unhook your front sway bar (or at least an end link) and hit the track. Depending on your power level, just be weary of the weak stock torque arm and you'll be fine.
I'd go with an anti roll bar and front adjustable drag shock. If the car is lowered some then some relocation brackets, or make your own to save some money if you have access to a welder, drill and grinder, can't imagine the metal would be over $15.00, at the same time you could also box in the LCA or box in the factory panhard rod to give those a little more strength which is super easy.
Your old car has !front swaybar, beefy rear swaybar, and front drag shocks. The car is going 1.45 on bottle, and 1.51-1.55 on motor with a tight converter. All you really need are the front shocks and a rear drag bar to keep the car from coming out cocked to one side.
You read my mind! Im going to have a front box my LCAs and the panhard
Even if its a min gain, it should still stiffen it up and its almost free so why not
