Drag Racing Tech
roll cage?
Old Oct 18, 2007 | 10:41 AM
hawk584's Avatar
Default roll cage?
how do you get a roll cage in a hard top? custom, one pipe at a time?
Old Oct 18, 2007 | 03:25 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
same as a t-top car, remove the interior slide the main hoop, measure cut and repeat till happy, then front bars, rocker bars, dash bar, rear bars etc.
Cut holes on the floor slide the hoop down through the holes so you can weld the top of the bars in repeat for all bars, then weld 6x6 plates over the holes and weld bottom of bars to plates.
Old Oct 18, 2007 | 07:12 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Moving to Drag Racing Tech...
Old Oct 18, 2007 | 09:55 PM
TwoFast4Lv's Avatar
That pretty much covers it!
Old Oct 19, 2007 | 08:02 PM
chrismorales75's Avatar
I would first, have subframes and outriggers to tie the cage into, then cut and fit the main hoop and "tack" it in.
Then do the front bars through the dash and dash bar and windshield bar across the top, "tack" those in good, then break the tacks on the main hoop, lower the whole front section down then finish weld that.
Then tilt it forward and retack on the main hoop and then fit and weld the rest in.
