What is the difference between the Wolfe single and double Anti-Roll Bar?
I am looking for the best traction possible.
If its adjustable, how do you adjust it and what differnces does adjusting make?
My car is not that fast. It should run high tens when I get it set up and tuned. Also the fastest I will probley get it is mid tens. It gets pretty good 60fts though. 1.47 best so far.
I am bracket racing though so if the double makes it hook even a little better than the single then thats what I want.
Do you stock those? If not how long would it take to get one?
I am making my own, but no one that I know makes them so maybe you guys could consider it.
On the Wolfe site there are installation instructions, but I don't see any adjustment instructions.
How do you adjust the bar once it is installed? What effect does it have on the car when adjustments are made?
Get the bar mounted up on the car first. once it's all set, hook up the drivers side link, and tighten it down so that the bar is level at ride height, or close to it. Now with you in the car, have the right side set so that the bolt holding the rod end to the bar can easily be slid in and out, this means there is no preload on the bar.
Start with it like that, the car should leave strait and level. If you find the car is rolling over on teh right rear, then make the rod on the passengers side a touch longer, if the car is lifting the passengers's side tire more, then the rod has to be shortened a touch.
Once you have the car leaving level and strait, I would then put the car on scales so that way you know where the weight's are that way if the car starts to run funny you can go back and check the weight's, see if anything has changed.
Much like a driveshaft, a hollow tube is stronger than a solid shaft.
We put one on my car and it goes super straight. We had a single billingsley bar on the car before and it was still laying over. I highly recommend the Wolfe Double for high horsepower applications.
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Just me but I can't see spending 400-500 or more on something I can make myself for 150.00 or less.
For mine I will be using a 1 1/2" torsion tube, with sealed bearings and using 1" .186 wall tubing tapped for 3/4" -5/8" hole rod ends and 1/4" plate for the arms with holes drilled and tied in together with welded tubing to brace the two arms together. I doubt that will ever break or I will over power it.
