Et gains from gear change
i have loved my 3.73 on a 325 radial with a low powered setup. what tire are you running and what is the result? IMO its ALL ABOUT the right converter. i dont care what the label says, its what it actually flashes to.
IMO, a gear change will actually hurt you as the bigger (numeric) gear, the tighter the converter acts. i think you should send the TCI converter back OR spray the bitch
gator, remember, its not that the conv. will flash lower nec., its the the gears are doin more of the work. so the car will drive better, and provide less conv. slippage/heat with the numerically higher gears. when I switched from 3:73 to 3:42's, I hated the change in rpms driving around town. rpms are HIGHER now on light acceleration from stop lights cause the eng is having to work harder to accelerate at X rate.
Thats why its called "Test & Tune". The part that could truely make you go broke.
how does it drive on the street compared to before? like it better with 4.10's or the old 3:73's around town?
congrats man.
but, running 11.3x with 4.10's compared to 11.5x with 3:73's and 1.63 sixties, you should see the gain in 60 as well as the ET. so Id guess you'll be running low 1.5x 60's now.
get back to the track and post up when you can give us some 60's too.
btw mike congrats. i bet you are ni the 1.5 60' esp considering that new ET. also congrats on 120 mph n/a!
