Drag Racing Tech
Back motor plate for LS1
Old Oct 25, 2007 | 03:48 PM
88SS LS1's Avatar
Default Back motor plate for LS1
Just wondering how you would connect a trans to a LS1 using the motor plate that goes behing the enigne on some high horspower engines. Due to the 1/2 clearance caused by the motor plate
Old Oct 25, 2007 | 04:06 PM
chrismorales75's Avatar
That's called a midplate and they are not 1/2 thick. Contact thunderracing.com, I know madman makes one.
http://www.thunderracing.com/catalog...id=166&sid=750
Old Oct 25, 2007 | 05:08 PM
MADMAN's Avatar
LS1Tech Sponsor
The plates are 1/8 inch thick and you will just need to tell your convertor guy that thickness.
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 25, 2007 | 05:12 PM
do you run engine travel limiters with your motor/midplate set ups?
I know some guys run a rod from the frame to the stock motor mount location or a close by bolt hole to limit forward/rearward movement.
Old Oct 26, 2007 | 06:11 AM
MADMAN's Avatar
LS1Tech Sponsor
Yes we run limiters to stop the fore aft movement.
__________________
225-343-9029
