Cage Build info
Where can i look this up?
Also you must have a certain amount of bars or "points" to met specific ET certification.
Also try to tie in sub frames to the cage rather than just floor plates, it is a little stronger and cleaner install.
For starter I would look at the wolferacecraft.com cage, they have one of the nicest looking "kits" around I have seen.
Custom stuff is always nice too if you can find detailed photos.
If you're going to build a cage I would make it to certify to 8.50's, then later you can add a funny car cage and the extra bars under the car you need later.
If you're going to also ever plan to go that fast use c-moly it will save you weight in the long run. A full blown funny car cage setup is a lot of bars and metal so the weight adds up quick.
