Building suspension?
For Heim joints I bought all that I needed at once from e-bay. It was the best price I could find. I think they are QA1.
I don't have any track time with anything I have built as the car is not finished but it has been worth a shot!!
Give it a shot!
Will your torque arm mount in a stationary bracket up front or use plates that pivot?
I can tell you how to make it a little more adjustable so you have about 50% more adjustment in the front.
Wheres a good place/brand to buy for the heims?
The same thing they use on offset lower control arms.
Thanks all the info from everyone so far.
3 or 4 holes up front isn't much, since it uses a slider I would recommend running 2 sets of holes 5 in the front and 5 behind those that staggers the hole location so you have 5 holes in the front and 5 holes behind and inbetween each one of those, so you actually get 10 location points of adjustment that will be much finer tuning than just holes stacked on top of each other.
You can also add sets of holes in the rear where the torque arm mounts to the rear, which would give you 20 possible location points for the t/a, lots of adjustably
