Drag Racing Tech
aluma-star vs drag lite
Old Nov 10, 2007 | 08:26 PM
SSPerformance's Avatar
Default aluma-star vs drag lite
how much lighter are they. tried looking on summit and they dont give no weight specs
Old Nov 11, 2007 | 10:50 AM
Steve Burger's Avatar
LS1TECH Sponsor
Not exact but both 15x10 alumastars are about the same as one pro star.
Old Nov 11, 2007 | 11:40 AM
how about the fronts
Old Nov 11, 2007 | 11:55 AM
joelster's Avatar
I'm going to add a bit to this too, because I want to know. What EXACTLY is the weight difference between the MOROSO front runner tires and a set of 165/85/15 street front tires. Those are the 2 options you have when running skinnies. I'm thinking the MOROSO tires aren't a belted radial and are probably worth a few lbs, but again, noone lists the weights. Some day I'm going to raid the summit warehouse with a scale and just weigh everything, cause this **** is important to us!
Old Nov 11, 2007 | 12:11 PM
the Ds2's are alot lighter dont no how much tho
Old Nov 11, 2007 | 01:47 PM
chrismorales75's Avatar
With the moroso weighing 12 pounds and the m/t sportsman front 8 ply weighing 19 pounds which would be the most comparable to actually weighing a 165 radial itself, would be a 7 pound per tire difference, adding the steel belts shouldn't add more than a pound so I would figure about 8-9 pounds per tire.
Old Nov 11, 2007 | 10:21 PM
foggedz's Avatar
My pro star skinnys with 165 radials mounted on them were 28lb each. With hoosier front runners they were 19lb each.
Old Nov 14, 2007 | 12:55 PM
1slowcar's Avatar
From a tech at Jeg's
ProStar
15x.3.5=10
15x10=15.5
AlumaStar
15x3.5=9.5
15x10=10.9
