Drag Racing Tech
What shock and spring combo do you guys recommend???
Old Nov 15, 2007 | 12:05 AM
CaMaRo67RS355's Avatar
Default What shock and spring combo do you guys recommend???
have a 02 SS M6 heads/cam/nitrous... sees track but is also driven alot on the road.
what kind of shock and spring setup are yall running that yall have had good success with?
Old Nov 15, 2007 | 08:18 AM
omcar's Avatar
Look into adjustable QA1s. Stocker Star for rear and R series for front.
Old Nov 15, 2007 | 08:36 AM
redneck01's Avatar
x2 for the qa1's....they're awesome!! ^^
Old Nov 15, 2007 | 09:22 AM
where can i get the best prices?
Old Nov 15, 2007 | 10:31 AM
chrismorales75's Avatar
I would use a strange double adjustable in the front so you can tune the compression and rebound, so you can have a 90/10 shock to drag race, a 40/50 for street driving and 80/70 if you ever want to road race, those are just examples of rates but you get the point.
In the rear a strange or qa1 single adjustable rear shock will work fine for all of the above applications.
For drag racing only I run a 275 front /150 rear spring, but since it is your street car i would maybe try a little stiffer rate, like a 300 front and a 160-175 in the rear. It will handle a little better than the softer springs.
Stiffer the spring the better the street driving will be and towards the softer side is more for drag racing.
Old Nov 15, 2007 | 10:39 AM
Matt D's Avatar
Retired Street Racer
QA1 "R"s in the front (90/10 with fixed compression) and Comp Engineering 50/50 in back is what I run. There are plenty of people going single digits with the same combo.
Old Nov 15, 2007 | 10:50 PM
ive talked to a couple guys that have that setup as well its very affordable too im seriously thinking about it
Old Nov 17, 2007 | 10:05 PM
SnakesRslow's Avatar
is the Stocker Star R-Series the same as the "R"s?
Old Nov 18, 2007 | 05:48 PM
James Montigny's Avatar
x3 ... love em
I run
HAL QA1 R-Series Front Shocks (12 pos)
HAL QA1 F-Series Rear Shocks (12 pos)
HAL QA1 300lbs Front Springs
(stock rear springs)
Old Nov 20, 2007 | 01:47 AM
NSTY WS6's Avatar
I take it most guys are running the 275-300 lb springs..but what length springs are you running?
I've read a few places about a longer, softer spring to hold more energy. I have a feeling you could get the suspension all outta wack with too soft a spring, thats too long, and the shock is put into overload while driving?
