Drag Racing Tech
pullin wheels off the ground ???
Old Nov 21, 2007 | 12:34 AM
daniel6718's Avatar
Originally Posted by Dave J
get some qa1`s and you will pull em nice
i didnt notice that shocks help that much....
if i do it ill get the right shocks and right sprigs the first time...afco double adjustables and 275 springs...but thats 800 bux...
Old Nov 21, 2007 | 09:44 PM
Candyredz28's Avatar
Has anybody lift the wheels off the ground with 2.73's???
Old Nov 21, 2007 | 11:01 PM
1BADAIR's Avatar
almost
Old Nov 21, 2007 | 11:40 PM
Wicked ls 1's Avatar
Originally Posted by Matt D
Sticky tire, negative pinion angle on the TA, drag shocks set on loose, and you will lift them if you hook.
I dont know Matt But when I click the pic finishline hijacked youre picture.
Old Nov 21, 2007 | 11:42 PM
Matt D's Avatar
Retired Street Racer
Haha, I know nothing about that...
Old Nov 22, 2007 | 02:24 AM
daniel6718's Avatar
i think gm muscle has
Old Nov 23, 2007 | 06:58 PM
01_ram-air's Avatar
Both of these were motor passes w/ 60's in the 1.6x range.
(not the best pic since it's a picture of a picture, but you get the point)
the back wheel really isn't turned in like it appears in the pic
This was done on completely stock suspension. I didn't have the suspension mods done that are in my sig now when this took place.
Old Nov 24, 2007 | 10:37 PM
Ego Killer's Avatar
slicks and a 150 should do the trick. pull the front sway bar just to make sure.
Old Nov 24, 2007 | 11:11 PM
donkey mule's Avatar
Does removing front sway bar realy make that much a differance and if so why?
Old Nov 24, 2007 | 11:32 PM
Ego Killer's Avatar
it just makes the front end real loose in turn just lets the front jump up a little faster making better weight transfer
Old Nov 24, 2007 | 11:54 PM
daniel6718's Avatar
wtf? i was cuttin 1.48-1.50 60' on stock suspension and coudent get mine up at all...
Old Nov 25, 2007 | 07:16 PM
  #32
rel3rd's Avatar
Originally Posted by NJSPDER
i think everyone is pointing to the same key, it si a traction thing. put the power on the ground and it will put the tires in teh air.
Exactly. I run a 2000 SS w/100% stock 112,000 mile suspension with NOTHING removed, at full weight, a fully loaded car with a fat driver and lift the driver's front wheel every launch.
Rather bland generic combo:
LS6 intake
226 cam
Longtubes, ORY, stock catback w/no cutout
3600 PI Vig. converter
342 rear
275/50/15 MT Drag Radials on 15x10" wheels/skinnies on front
Best run (yesterday): 11.67@115 w/1.58 60'
Old Nov 25, 2007 | 08:17 PM
  #33
Sluggish's Avatar
ET streets, QA1s, 9"+ 6k clutch dump= left wheel up, until the battery rolls back and grounds out. Then the car dies in mid air.
Old Nov 27, 2007 | 11:26 PM
  #34
LSmokin1's Avatar
Old Nov 27, 2007 | 11:28 PM
  #35
Looks like you were about to see sky on that launch!
Old Nov 28, 2007 | 01:16 PM
  #36
matsge's Avatar
Loose front suspension ,same weight front- rear,5500 stall ,4.56 good traction.
Old Nov 28, 2007 | 05:14 PM
  #37
jmill96Z's Avatar
I can't get mine to lift either. I launch on the spray and run deep 10's. I can't figure it out to save my life. I think I'm gonna try the Madman sway bar at some point this year to get a nice 6-8 inch lift.
See attached video. It just seems like the weight transfer isn't there
Old Nov 28, 2007 | 05:48 PM
  #38
daniel6718's Avatar
me 2...my front will lift about 6-8 inches has good weight transfer but wont lift them...and my cars prolly in the 3200 rangei put front runner on it now and it still wont...no front swaybar and stock rear bar...i would think the stock rear would allow twist and at least lift the left front
http://s21.photobucket.com/albums/b2...t=b0e8f0f6.flv
3600 stall flashed on 125 shot
Old Nov 28, 2007 | 05:53 PM
  #39
GregWS6&z28's Avatar
my 2.73 launch on motor looked like 1BadAir's
with heavy *** Boyd Coddingtons on the front.
