pullin wheels off the ground ???
i would suggest a bigger stall, think 4000-4400 and take advantage of everything that engine has off the line.
If you still have a front sway bar take it off
Sticky tires
Spool
Short TA
Lose as much weight as possible off the fornt
Transbrake
90/10 front shocks
Mods:
ET Drag radials
TCI 3600 stall converter (only getting 3,300 flash when I leave)
full lenghts, offroad Y-pipe with a cutout.
stock 3.23 gear
no front sway bar
Full race weight 3680 (with me in the car)
UMI lower rear control arms
UMI Frame ties
Stock internals
Ls6 intake
i think everyone is pointing to the same key, it si a traction thing. put the power on the ground and it will put the tires in teh air.
My pig cuts 1.50 60's on the spray and barely lifts the fronts for a sec. 3600+ lbs street car with a/c. lol.
3000lbs
!front sway
front qa1's at 4
LCA
sphon TA
rear air bag 35psi
lakewood 50/50 rears
M&H 28'' tall, 17'' DR
Im glad it doesnt pull them, put everyone wants a good wheelie every once and awhile
