Drag Racing Tech
What K-Member to use
Old Nov 25, 2007 | 11:28 AM
T Pizzle's Avatar
Thanks Steve for the PM. It helped with my decision to go with the Burkhart Stuff
Old Nov 25, 2007 | 01:37 PM
Steve Burger's Avatar
LS1TECH Sponsor
Glad to hear that. Let me know if there is anything else I can do. I talk with them several time a week. They are a large part of my current build.Mot Chassis related either.
Old Dec 16, 2007 | 07:55 PM
jakesz28's Avatar
Well I just ordered the pa racing one without motor mounts. I hope it fits decent.
Old Dec 18, 2007 | 01:14 AM
WMSuperSport's Avatar
BMR fits great but only saved 27 pounds with lower control arms.
Old Dec 18, 2007 | 02:13 AM
LC's Avatar
LC
any pics of the burkhart piece?
Old Dec 18, 2007 | 06:41 AM
Matt D's Avatar
Retired Street Racer
http://www.burkhartchassis.com/fbodycomponets.html
Old Dec 18, 2007 | 06:42 AM
Matt D's Avatar
That is what I went with as well. Chrome moly k-member and upper & lower a-arms.
Old Dec 18, 2007 | 03:16 PM
LC's Avatar
LC
i have seen that, but what about bigger, close up pictures...
Old Dec 18, 2007 | 03:18 PM
3fingas's Avatar
S&W makes a nice one, not sure if there a sponser.
Old Dec 18, 2007 | 04:16 PM
LS1TECH Sponsor
Let me know what you want to see. I can get pics this weekend.
Old Dec 18, 2007 | 07:11 PM
flyinZ's Avatar
Anybody ever think of the Spohn or UMI unit?
Old Dec 18, 2007 | 07:23 PM
  #32
Reject's Avatar
Originally Posted by NHRAMAN
I have been considering going this route also----mine is just STREET though..[couple/3 times a year down the track]....I want one that will be sturdy/strong enough for trips and so forth...no crazy driving......BMR is good for this route.???? Please anyone chime in..thanx. [I am more into losing some weight on the front than anything else.]
same here, i'm trying to decide which would be the strongest for "daily driver" duty
Old Dec 18, 2007 | 07:53 PM
  #33
hvyhttter's Avatar
I have a BMR unit and installed a PA and a Racecraft piece. PA is the lightest by 3 lbs and BMR is definatley the heaviest, but the racecraft piece is in my opinion is the best. The only thing that is a negative is you have to make tabs for the brake line. no biggie
Old Dec 18, 2007 | 08:11 PM
  #34
Reject's Avatar
do you all think the BMR turbo k-member is by any chance weaker than the regular one?
Old Dec 18, 2007 | 10:03 PM
  #35
foggedz's Avatar
Can you post up or PM me some pictures of what this kmember looks like with the motor mounts. I am looking a LT1 Kmember that has the entire motor mount setup built into the kmember. Not one that just has pads where you can use all or part of your stock engine mounts. I thought this would be easy to come by but apparently its not. I tryed to get ahold of PA but never could. I also tryed to email Thunder Racing because they sell them, and are always great with answering questions, but got no answer from them eather.
Old Dec 18, 2007 | 11:07 PM
  #36
G&HRacing's Avatar
8 second club
Originally Posted by BadBoo79
I have the PA racing one in my '00 Camaro with the Pinto rack and it is not good. It took some custom fabricating to get the rack mounted right and their tech help is non-existant. Go with the AJE!
I agree, having owned PA's and having a couple of friends with PA's. I'd suggest buying from anyone but PA.
Old Dec 19, 2007 | 06:40 PM
  #37
jakesz28's Avatar
I can take some pictures when I get it but I ordered it without mounts. I will be running motor plates so I went this route to save some extra weight.
Old Dec 19, 2007 | 10:47 PM
  #38
foggedz's Avatar
Ohh sorry I miss read your original post. I thought you got one with mounts. I have seen pictures of the ones with out mounts.
So does anyone make a K-member for a LT1 that has the full motor mount built in. BMRs has some kind of odd poly mount, plus they dont make them out of chromoly. Spohns is setup to use the stock motor mounts, that are cast iron and heavy as hell. I believe AJE uses a similar poly mount.
The only solution that I have come up with so far is to get a Spohn K-member, and the Madman solid mounts that are designed to replace the stock mounts. This would put me at $700 for the K-member, and another $200 for motor mounts. $900 is a little much for a setup that I figured most everyone would offer.
Does anyone have any Pics of there PA k-member with mounts built in?
Old Dec 20, 2007 | 12:22 AM
  #39
Josh@KY-Turbo's Avatar
I have seen the BMR Turbo K-Member in person on a car being built at a local shop. It is by far the best solution to for a k-member that will be on a Turbo charged car. Plenty of room for a 4" DP and still be able to Keep the AC intact. This is all while using the stock motor mounts.
If you were looking to build a full out Turbo, Blower, Nitrous, or N/A race car I would go with the Burkhart Hands down. Motor plates and all. That setup is the **** IMO...
Old Dec 20, 2007 | 08:39 AM
  #40
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a PA on my Formula with BMR uppers and lowers, and am researching one for my Camaro, was leaning towards UMI.
