Drag Racing Tech
What K-Member to use
Old Dec 20, 2007 | 09:05 AM
  #41
WMSuperSport's Avatar
So far, I think it's give and take.
The BMR is heavier, but fitment is great and its strong.
The PA is a hair lighter, but fitment seems to suck and I'm not sure it can hold up to road racing...
The UMI is supposed to be kind of heavy, also, but definitely strong enough and I've heard good fitment quality.
I only have personal experience with the BMR, but don't be fooled by those crazy weight savings numbers...they're a "little" exaggerated.
Old Dec 20, 2007 | 09:46 AM
  #42
UMI Performance's Avatar
Hello Members,
We also offer a very nice K-member set-up. I will agree it is not the lightest one on the market however during the build and design lightest as not our goal. We designed a item that is considered "multi" use, we recommend it for both drag racing and street use including daily driven vehicles. We also offer a step up for road race applications where additional pressure is applied to the front end.
If anyone has any questions regarding our set-up please feel free to contact us. We currently have this item with built in motor mount stands for the LT1 and LS1 or for $50 less we have them with no motor mounts to be used with motor plates.
For additional pictures please visit out site.
Thank you!
Ryan
Old Dec 20, 2007 | 10:31 AM
  #43
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What's the conventional wisdom on k-members, that mild steel is better for street cars? I'm curious.
Old Dec 20, 2007 | 11:13 AM
  #44
foggedz's Avatar
Originally Posted by UMI Performance
Hello Members,
Thank you!
Ryan
What does your LT1 K-member look like? This picture looks like it has mounts for a LS1, and I believe you have these same pictures listed under the LT1 item description on your site.
Old Dec 20, 2007 | 01:34 PM
  #45
Reject's Avatar
do you think you would be able to custom make it to have more clearence room for a turbo downpipe like the BMR units?
Old Dec 20, 2007 | 07:49 PM
  #46
jakesz28's Avatar
I have a PA on my Formula with BMR uppers and lowers, and am researching one for my Camaro, was leaning towards UMI.
How do youu like the PA , one.
Old Dec 20, 2007 | 08:00 PM
  #47
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thanx for answering my question...UMI Performance.
Old Dec 21, 2007 | 08:47 AM
  #48
The LT1 K-member can be seen here- www.umiperformance.com/2325
The only difference is the motor mounts... the rest of the K-member is the same. So we do use some of the same pictures but the main picture in the above link is a LT1 specific K-member.
Hope that helps!
Ryan
Old Dec 21, 2007 | 10:09 AM
  #49
stroked_408's Avatar
http://paracing.com/product_info.php...8d731fe9dac65f
Old Dec 21, 2007 | 10:36 AM
  #50
foggedz's Avatar
Hope that helps!
Ryan
Ok, ic. Per your description this K-member is supposed to eliminate the cast iron engine mounts. This K-member would eliminate one of them, but the cast iron mount that bolts to the block on the passanger side would still be used with your K-member. I realy want to get rid of both of the cast iron mounts.
Old Dec 21, 2007 | 10:52 PM
  #51
nyytrousboy's Avatar
Thumbs up Mildsteel vs Moly
John, it all depends on what thickness your comparing. I think Mildsteel is better for all out street use. I tend to lean towards the moly for limited street use and all out racing.
Old Dec 21, 2007 | 11:11 PM
  #52
LS1-STANG's Avatar
I have the PA Racing K member upper & lower control arms... The fit was perfect and i daily drive the car in the nice weather ... I have 5k miles on the complete set up so far no probelms just came back from the Maryland car cruise in Oct i drove the car up & back its a TRUE STREET CAR
Old Dec 22, 2007 | 09:16 AM
  #53
The factory LT1 K-member only has ONE cast iron motor mount stand. The passenger side motor mount bolts directly to the K-member, this is why our design looks as it does. All you do is bolt your factory rubber motor mounts to our K-member. Take a second and look under your hood and you will see
Let me know if I can help anymore. Thanks!
Ryan
Old Dec 22, 2007 | 11:42 AM
  #54
foggedz's Avatar
Ryan
Im sorry, but the passenger side motor mount is 2pc just like the drives side. On the drivers side the cast iron portion of the mount bolts to the K-member and the rubber portion of the mount bolts to the block. On the passenger side the rubber mount bolts to the K-member and the cast iron portion of the mount bolts to the the motor. Here are some pictures I found doing a quick search.
This is a picture from the front of the motor. The cast iron portions of the mounts are red, and clearly on both sides.
Passenger side mount, with cast iron portion bolted to the motor.
Old Dec 23, 2007 | 10:59 AM
  #55
Yes I understand that, but in that picture the rubber motor mount bolts directly to the K-member. We do not call that item you are referring to a cast iron stand, it is referred as a clam shell. The drivers side uses what we call a motor stand on the LT1 models and the LS1 uses it on both sides. The only way to get rid of those clamshell's is to run a solid motor mount built into the K-member. Otherwise in order to run a factory rubber motor mount you need to reuse your factory clam shell's. The way the motor mount is bolted directly to the K-member in your picture is the exact way ours works.
Hope that helps,
Ryan
Old Dec 23, 2007 | 11:07 AM
  #56
foggedz's Avatar
This is what ive been looking for, but know one offers them. I just ordered a PA k-member with LT1 motor mount pads built in and Madman solid LT1 motor mounts. Hopefully these parts will all work together.
Old Dec 29, 2007 | 05:29 PM
  #57
jakesz28's Avatar
I got the PA k member(without motor mounts) and it looks good. It was only 18lbs so does anyone know how much a stock LT1 k-member and motor mounts weigh?
Old Dec 29, 2007 | 05:56 PM
  #58
Josh@KY-Turbo's Avatar
As it stands right now I am getting the funds together for the complet BurkHart Suspension. My 99 Z28 is gonna be more race car than it will ever be street car anyway.
Old Dec 29, 2007 | 06:54 PM
  #59
studderin's Avatar
Originally Posted by WMSuperSport
BMR fits great but only saved 27 pounds with lower control arms.
On what model Kmember, with what mount mounts. For that weight diffrence?
A GM LS1 Kmember with the cast iron engine stands weights 56-57Lbs.
The current normal BMR steel Kmembers with LS1 stands weighs 25lbs FYI. How did you only get 27lb savings with LCAs also? Was that an older one without the egine stands, and you had to reuse the heavy cast iron ones?
Dose anyone else, have weights of there parts they can list.
Old Dec 29, 2007 | 07:32 PM
  #60
Our K-member with lower A-Arms saves 33 lbs
