Drag Racing Tech
Lets see some pics of your weight ballasts
Old Nov 25, 2007 | 11:09 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Default Lets see some pics of your weight ballasts
For those of you that run index and weight classes, lets see your ballast set up to control weight requirements or ET control.
Old Nov 25, 2007 | 11:58 PM
Dave J's Avatar
I run index but I use my digital7 box to retard the launch timing
or set the 2 step lower
Old Nov 26, 2007 | 10:31 AM
mrdragster1970's Avatar
6 & 8 Second Club
Don't have pictures handy. The best & most common way I've seen is square tube with lead shot. You can make them single weight or adjustable.
You weld 2 small thru tubes for bolts to where you can bolt to chassis. I don't like clamps or brackets. The thru tubes will never break or come loose. If you want adjustable, then you weld in a cap, like a rear end fill cap, works good. Hopefully someone will have photos for you.
Old Nov 26, 2007 | 07:30 PM
joelster's Avatar
I remember seeing an f-bod from here that had a spare cylinder head bolted near a rollcage tube on the pass side of the car. That's an easy 45lbs.
Old Nov 26, 2007 | 09:52 PM
LC's Avatar
LC
a pair of 15lb nitrous bottles.. full of course
Old Nov 27, 2007 | 12:30 AM
Bhogan909's Avatar
If I remember correctly Texas Speed used some ballast in their Red Z28 in 2004 at the race at US-41. I think they were tractor weights and they had them behind the rear bumper. May ask Jason or Trevor.
Old Nov 27, 2007 | 12:53 AM
TXCAMSS's Avatar
I'm sure I can fab something up that will work fine and be legal. I was just hoping to get to see some existing ballast setups.
I have a system that is very effective, but it ain't pretty.lol.
Old Nov 27, 2007 | 09:21 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd like to see too.
Old Nov 27, 2007 | 07:07 PM
Bg Drg's Avatar
John,
I have quite a few pics from some of our old cars, but I cannot shrink them enough to post. Maybe I could send them to you?
Jay
Old Nov 27, 2007 | 07:23 PM
TXCAMSS's Avatar
Jay send them to me at james.day007@sbcglobal.net. I'll host them.
Good to see ya checking in on us
We sure miss ya!
Old Nov 27, 2007 | 07:29 PM
Brady's Avatar
LS1Tech Sponsor
LOL
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Nov 27, 2007 | 08:28 PM
Z8'S's Avatar
I built a box tube that has been capped on both ends with a fill plug. Empty it weighs 22 lbs. I can fill it with lead shot to approx.75 lbs.It bolts into the original rear bumper location.
Hi Jay!!
Old Nov 27, 2007 | 08:58 PM
Krazy98Z28's Avatar
Originally Posted by Brady
LOL
We used that in a mustang a couple months ago to make weight. We had to be 3100 and we were 2900. slowed us down 2 tenths
Old Nov 27, 2007 | 09:48 PM
chrismorales75's Avatar
Some of my buddys would run lead bars with holes drilled through them to mount in certain locations, changing the weight was just running bigger or smaller bars of lead.
They would profile the bars to certain weights and stamp them, then just unbolt/bolt in other weight bars. I think some of the bars were 50 pounds, they are pretty big.
You could use depleted uranium that's heavy
Old Nov 28, 2007 | 11:43 AM
TXCAMSS's Avatar
Good info guys!!!! Keep'em comi'n!
Old Nov 28, 2007 | 11:55 AM
Hawkn01's Avatar
I used 10" x 4 3/4" weight machine bars that weighed 10lbs apeice. I bolted them in the rear inside the car over the axle with 1/2" allthread rod. I had 200lbs of them in the car...LOL ! Looked like a jungle Jim back there but it worked.
GM High Tech had a picture of the weights in my car in the article they did on the LS1Tech Eastcoast Shootout in 2005.
Old Nov 28, 2007 | 12:08 PM
brandonppr's Avatar
I would love to see some pics as well.
Old Nov 28, 2007 | 01:11 PM
LS1Tech Co-Founder
Hi Jay!
Yah any pics would be cool.
Old Nov 28, 2007 | 05:11 PM
9sec93's Avatar
not a good idea if you plan to reproduce though. lol
Old Oct 3, 2011 | 04:29 AM
Vetal's Avatar
Maybe now someone can add some pics?
How much could you gain on very bad track with the added weight? I spin through 1st and 2nd gear on my track with merely 400-450whp
