Drag Racing Tech
Susp. question....paging madman.....
Old Nov 26, 2007 | 09:04 AM
ATVracr's Avatar
Default Susp. question....paging madman.....
My car leaves crooked and I am wondering if a drag sway bar will help level it out?
Right now it has a 1" spohn with poly ends.
Also is there anything to be gained by going to rod ends on my LCA and TQ arm?
I have the limiters tight and it still wheelied on the one pass, can a drag sway bar that we can preload help keep the front down any?
Thanks for any help.
here are a few pics and a short video............
Video .... http://www.glenburnieracing.com/waynes908.wmv
Old Nov 26, 2007 | 09:08 AM
MADMAN's Avatar
LS1Tech Sponsor
Put a Wolfe antiroll on it. It will take the roll out of it. I like the rod ends because I know there isnt any deflection like the urethane has.
__________________
www.madmanandcoracing.com
225-343-9029
Old Nov 26, 2007 | 09:27 AM
ATVracr's Avatar
Would your TQ arm help with keeping the front end down? I have the spohn right now.
I'm thinking of replacing everything for next year, do you have a coil over option for your rear susp. package?
Thanks.
Old Nov 26, 2007 | 10:04 AM
MADMAN's Avatar
LS1Tech Sponsor
Call me and we can discuss.
877-516-7223 ask for me.
__________________
225-343-9029
Old Nov 26, 2007 | 12:13 PM
chrismorales75's Avatar
2x with madman that thing needs a drag anti roll bar.
Old Nov 26, 2007 | 12:54 PM
T Pizzle's Avatar
Anti-Roll bar would help out allot
Old Nov 26, 2007 | 01:16 PM
koolrayz's Avatar
Here is my car leaving with the same sway bar and TQ arm. I have a full weight iron blocked car. Mine used to leave like yours did so I put the bags in the springs last winter and it really helped alot. In the end I would like to go to the anti-sway bar but the bags work and cost next to nothing.
Old Nov 26, 2007 | 01:47 PM
ATVracr's Avatar
My car left strait until I strapped the front end down tight with Madmans limiters.
So now instead of the shocks throwing the front end up the chassis is lifting the front and the sway bar has to much flex to handle it.
Brian, I'll call you when I'm ready to order. Thanks for the help.
Old Nov 26, 2007 | 07:24 PM
JL ws-6's Avatar
Race your car!
wow you got a 9.05 out of the car with it leaving like that? That's nuts, get that thign leavign level and it will probably go .2 faster just from that I bet. That's some serious rollover!
Old Nov 26, 2007 | 08:31 PM
Our buddy paul broke his anti roll bar and had the right front on the ground and the left front well over 18" off the ground before he lifted, he runs low 8's on a 275 60 15 drag radial.
A working anti roll bar correctly set up is a very good thing to have.
Old Nov 26, 2007 | 09:21 PM
ATVracr's Avatar
I dont know about that .....but it would be nice.
It cut a 1.28 60' on that pass.
Old Nov 27, 2007 | 05:15 AM
JL ws-6's Avatar
Race your car!
Well it runs, may not be pretty but it runs.
I still think getting it level will make a good improvment.
Old Nov 27, 2007 | 09:52 AM
T/ALT1's Avatar
Are you running a stock swaybar now?
Old Nov 27, 2007 | 10:13 AM
ATVracr's Avatar
no.
Spohn 1" with poly bushings.
Old Nov 27, 2007 | 10:34 AM
WS6TransAm01's Avatar
CARTEK Racing
Im sure there is a lot to be gained from going to a heavy duty rear sway for you. Aside for stability I would imagine it would net you a better 60' if both rear tires have the same or similar amount of weight on them.
I was wondering something similar; my car leaves strait with both wheels an equal distance off the ground, I have a suspension techniques 25mm sway bar with poly busings. Will a hardcore rear anti-roll bar help my 60'? Of do they only make the car come out even, in which case it will not help?
Old Nov 27, 2007 | 02:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running a Spohn drag bar in the Formy (1.35) and a BMR drag bar in the camaro (1.38).
Old Nov 30, 2007 | 11:57 AM
MIGHTYMOUSE's Avatar
i'll take a 1.28, lemme know if you're going to sell the spohn bar, im not putting a solid bar on my car.
Old Nov 30, 2007 | 02:04 PM
ATVracr's Avatar
I'll trade you my sway bar for your turbo.
I'll let you know when I take it off.
Old Nov 30, 2007 | 02:45 PM
Fireball's Avatar
You can buy my turbo
Old Nov 30, 2007 | 03:13 PM
ATVracr's Avatar
I was joking with MM.
We need two 76's
