Drag Racing Tech
T56 Trans Blanket?
Old Nov 26, 2007 | 11:27 AM
MetallicaMatt's Avatar
Default T56 Trans Blanket?
Last time I checked, there wasn't an 'official' trans blanket for the bellhousing of the Fbody T56? I know McLeod or someone makes a special housing, but I know its a PITA to put on.
Is there a blanket out there yet?
I really don't want my clutch in my legs.....
Old Nov 28, 2007 | 09:11 PM
badpewter-z's Avatar
LS1TECH Sponsor
just get the bellhousing, i wouldnt trust a blanket if the clutch goes. i was thinking the same thing and ended up wit the bellhousing. plus the blankets arnt sfi approved for stick cars
Old Nov 29, 2007 | 11:05 AM
Thats what I was afraid of...
Damn, now I gotta pull the trans again lol
Old Nov 29, 2007 | 11:08 AM
Bitemark46's Avatar
Matt, I'm in the same boat. They don't make a SFI BH for my tranny. So I used 2 blankets and wrapped them around the BH for a band aid fix. -Mark
Old Nov 29, 2007 | 05:13 PM
I was thinking about doing that Mark....I figure a blanket is better than nothing at all
If i remember right the SFI BH was over $700 or so...
Old Nov 29, 2007 | 08:06 PM
will62085's Avatar
The blanket will not be sufficient. They are made for auto's, to catch small pieces of metal, not large heavy pieces of clutch.
do not be fooled by the SFI rating, the blanket is designed and tested on auto trans applications, that is what this rating is for.
Old Nov 29, 2007 | 09:19 PM
who sells the bellhousing again? I really don't wanna pull that trans lol
guess we'll find out
Old Nov 29, 2007 | 09:33 PM
will62085's Avatar
for the LS1? not sure. Mcleod? quicktime? I know there are a few for the LS1
Us LT1 guys have to convert clutches and all this bs to get one in our cars...lame..
Old Nov 29, 2007 | 10:14 PM
CutlassRacer's Avatar
LS1TECH Sponsor
Man I feel sorry for the guys with fast stick shift cars out there. I have done a few clutch swaps on cars with NHRA legal bellhousings and all of those extra bolts are a pain in the butt!!
I guess its safer than having a clutch part come through your leg though!
Old Nov 29, 2007 | 11:21 PM
LS1TECH Sponsor
mcleaod is the only one and its not a direct fit for the ls1, check my sig
its a bitch but worth my feet
Old Nov 30, 2007 | 07:41 AM
WFOWS6_IL's Avatar
I put the McLeod housing in with my new motor out of the car. It's a pain in the arsh, but it's on there now.
Problems I had:
1. There was clearnance issues between the motorplate to flywheel. Had to grind down the motor plate so the flywheel didn't touch.
2. The holes didn't line up exactly right from bell to block and had to woller a couple out. Sounds hookey, but the problem was there.
3. No cut out to bleed the slave. Had to use a Snap-On remer bit to open that up.
4. Had to cut a section of the "other" started bevel out for header clearance on the left side.
5. Wrong bolts came with the housing. They give you standard thread. Buy allen headed bolts cause a regular headed bolt wont allow a socket to hit.
6. Had to get a custom shim for the slave since the housing is deeper than stock with the motor plate. Was 7/32s to be precise.
Luckily everything lines up right with the dowels. I was really getting concerned since I had to do all the above work.
Definetly mock everything up and check clearance!
Old Nov 30, 2007 | 03:51 PM
ugh
do i really need feet? lol
Maybe I should just weld some thick stainless plates on the underside of my car lol
Problems I had:
Old Nov 30, 2007 | 08:57 PM
LS1TECH Sponsor
you shouldn't have to grind the motor plate if you grind the oil pan back so its flush with the motor. thats what i did on mine and another car we put on on. defeinetly get the allen heads too
Old Dec 3, 2007 | 07:34 AM
WFOWS6_IL's Avatar
Opps, forgot to mention I grinded that down too. Still had the issue. Called McLeod and they stated that you "might" have to grind the motor plate down. Flywheel was touching around the openning for the crank, top side, on the motor plate. Good thing I was observant on that.
All in all, I feel safer having it on there.
Old Dec 3, 2007 | 11:15 AM
looks like I'll be getting one.
just warn the family for all of the cussing and swearing coming from the garage lol
I just bought a nice new dremel, will that get the job done? or am I going to have to get out my Dotco cutting wheel?
