Drag Racing Tech
Weight ?'s
Old Dec 5, 2007 | 07:37 PM
01blackz28's Avatar
Default Weight ?'s
Hey guys how much do u think a car weighs with the following weight reductions: (its a 93 hardtop with an ls1 in it)
!front and rear bumper supports
Cut the extra metal on the fender supports
1 kirke aluminum drag seats
!abs
!heating lines and acces.
!a/c and all the junk with it
!ebrake
TH-350 tranny
!spare tire and jack
!wipers and motor
BMR torque arm
BMR tubular front end
15"Draglites all the way around w/ skinnies on the front and 28x10 on the back
!rear speakers
Gutted stock carpet
! rear speakers (may get rid of the whole radio system)
trimed metal behind fenders
removed backing supports for bumper mounts about
still thinking about removing power steering and adding a electric water pump.
Future: May have to put a cage and a 9" in it
I will have QA1's installed shortly and light weight brakes. Anything else easy you can think of? I don't want to take out the doorbars for safety reasons (no cage). How much do you think this car weighs? I mean it looks like there is no motor in the front of this car thats how high it sits.
Old Dec 5, 2007 | 07:40 PM
RAGENZ28's Avatar
Best way is to look at the weight sticky and add up all the stuff you took out.
If I had to guess I would say 3,100 something
Old Dec 5, 2007 | 07:52 PM
Taubr Unit's Avatar
i have more then you out but im still a lt1 vs. your ls1 and mine is 29xx. Mine is damn near a tin can with no carpet, 1 drag seat and everything under the sun removed.
Old Dec 5, 2007 | 08:00 PM
RAGENZ28's Avatar
Hell I hope my car comes out light, it sure is getting easier to roll around lol.
I have no bumpers, no spare tire or jack, removed 53 pounds from mini tubbing, took out the carpet and will run that light weight stuff, took out all of the heater and a/c stuff, removed the power steering pump, I think mine was 3150 before I mini tubbed it or took out the power steering pump, or the bumpers. So I think I have taken an extra 140 or so pounds, man I'd love to get it under 3000k
Oh I think I had 18"s on the car too so minus weight for the drag rims and also went with rear wilwood brakes, maybe I am under 3k
Old Dec 5, 2007 | 08:04 PM
Taubr Unit's Avatar
I took everything out also...
--low mount alternator
--deleted all acceries on motor
--VFN 3'' SS fiberglass hood, pin-on
--no windshield wipers or motor, everything gone
--car still has power locks and windows
--Weld Prostars with Goodyear front runners and M/T ET street tires
--1 racing seat
--no carpet
--no rear seats
--no interior trim pieces
--Grant steering wheel
--stock radio with 2 door speakers, no rears
--no visors
--Dash has been removed to strip out weight from behind it
--both air bags removed
--removed ABS
--TCI line lock
--battery mounted in rear
--no heat or acc.
--no AC or acc.
--no e-brake or handle
--no power stearing
Old Dec 5, 2007 | 09:09 PM
01blackz28's Avatar
taubr do u have sfc? i forgot to add that i do
Old Dec 5, 2007 | 09:25 PM
Taubr Unit's Avatar
--welded in subframe connectors
--bigger sway bar in rear with welded brackets on the rearend
--stock springs with 1 coil cut
--stock shocks
--Behind Bars race cars panhard bar
--UMI torque arm with driveshaft safety loop
--front QA1 "R" coil over shocks
Old Dec 5, 2007 | 11:17 PM
RAGENZ28's Avatar
--1 racing seat
--no carpet
--no rear seats
--no visors
--removed ABS
--TCI line lock
--no heat or acc.
--no AC or acc.
--no power stearing
WOW Now I think it is time to break out the hole saw.
Old Jan 13, 2008 | 08:20 PM
jakesz28's Avatar
I'm not willing to have the stripped look. I'll be leaving trim in and running some light weight carpet. It would be nice to get down to a 3200-3300 race weight.
Man I could stand to lose the 30lbs I put back on since I quit working out.
Old Jan 14, 2008 | 08:37 AM
Matt D's Avatar
Retired Street Racer
I would say it is around 2900-3000. Mine is 2825 now, and will be down to 2700 after the drag brake setup, lightweight battery, and door bar removal.
