Drag Racing Tech
M6 racers help please...
Old Jun 24, 2003 | 08:26 PM
LOnSLO's Avatar
Default M6 racers help please...
OK, old clutch is history, new clutch on the way. Here's a question I have regarding 60 foots and clutch strength. Let's say I have the mack daddy mega grip clutch rated at 1500 horsepower. I have around 500 or so actually going to it. Will I bog off the line from a 6700 rpm dump? Is it actually better to get a clutch that slips a little so rpms don't drop so low? I need help and fast! Thanks.
Mods, please leave this in drag racing. I'd like to hear from some of the big time M6 racers on this issue.
Old Jun 24, 2003 | 08:34 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Default Re: M6 racers help please...
I made over 300 passes last year at 6,500 rpms with no problems. :p
My Hot Rod did not bog off the line at all and I was using the Mcloed Rev Lock.
Thunder Racing was the hook up.
Coach
Old Jun 24, 2003 | 08:38 PM
LOnSLO's Avatar
Coach, I'm going from a SPEC stage 3 to a stage 5 unsprung iron disk. Now I'm worried about 60 foots. Any advice?
Old Jun 24, 2003 | 08:46 PM
Ron@Vengeance's Avatar
Sign on IM biatch!!!
BTW, you will be fine
Old Jun 24, 2003 | 09:02 PM
I agree. You will be fine. Go for it brother.
Coach
Old Jun 24, 2003 | 09:07 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Dump it on the rev limiter,trust me it won't bog.Hope you got a good tire on the back.Enjoy
Old Jun 24, 2003 | 09:19 PM
LOnSLO's Avatar
Good deal. Thanks for the confidence builder guys
Old Jun 25, 2003 | 01:58 PM
1madss's Avatar
With the 4.30 gears and a 27" tire bogging should not be a problem ,just keep the RPMS high at launch. I use the RAM 402/6130 setup with a 26" tire and launch at 6600 without a problem.
